MoltoMario
05-31-2010, 10:12 PM
Posting my 1 of 1 Stanced Chrysler Conquest or otherwise known Mitsubishi Starion. Car is one of the cleanest around. I really just want to try something new. Im really leaning towards a Benz 190E 16v or E30 M3 possibly. Keep in mind I don't have to sell the car or trade, but I figured why not at least see.
Ive poured all my effort into this car and I really feel its definitely one of the nicest/best built StarQuests anywhere around!
The car itself is in decent shape. A few dents and scratches here and there..nothing big. The interior is good other then the usual wear on the drivers seat on the side bolster and bottom on the seat.
The car has a lot of rare parts as well as very high end parts. I didn't skimp out on anything on it!
This car is really QUICK! it WILL put you in the back seat = )
The car is currently set at 15lbs of boost for daily, but with 1 push of a button on the Greddy boost controller the boost can be set to 20lbs. Starion Bottom ends are almost indestructible guys. They have been proven to handle over 700hp on the stock block. With a bigger turbo this car would Screeeeeem!
Engine/Performance/Go Fast Goodies!
-89 Conquest Fiji blue SHP 100k Miles
-KDM full hard pipe kit.
-KDM 3 inch exhaust with flew pipe
-KDM modified intercooler
-TEP Griffin aluminum radiator
-3 wire o2
-Brand New NGK Spark Plug Wires
-Greddy electronic boost controller
-Cobalt autometer gauges( Boost,Oil Pressure, Oil Temp, Voltage)
-ACT xtreme pressure plate with the street disc. Lightened flywheel, new clutch master and slave, steel braided clutch line.
- Short throw shifter
-Turbo xs RFL blow off valve
- AMC Non jet valve head and Ajusa head gasket
-MK1 gauge overlays
-1st gen MAS DSM
-ABS Eliminated
-S16G Turbo
-AEM Uego Wideband
-Nardi Suede Deep Corn Steering Wheel
-Areomotive Fuel Pressure Regulator
-Custom Powder coated Valve cover( Metallic Purple with some Flake in it)
-Restored 83 Tail Lights. Taken Apart, Cleaned, painted, and re-glued
-Every Line is braided/Everything from Brakes to Coolant lines
-Greddy 80mm Silencer
-Greddy Ti-C Muffler
-Brand New OEM Airdam painted to match.
-Brand New Cat To Fit in Where the Test Pipe Goes For Smog
-Replaced wheel bearings when I installed the Mookeeh Coils
-I also replaced ALL of the braided lines with New Lines and XRP fittings as the old cheap ones all started to leak.
Im sure theres even more but this is all I can think of off the top of my head
Suspension
- Mookeeh Full-body coilovers. Not Sleeve overs guys
- Mookeeh Front and Rear Camber Plates
- Suspension Technics front and rear sway bars
- Cusco Front Strut Bar
Wheel Fitment
03-04 Cobras
Front 18x9 -6
Rear 18x10.5 -23
Front Tires 225/40/18 Bfgoodrich KDWs
Rear Tires 235/40/18 Feddys
Tires have about 200 miles on them.
Car is currently "Stanced" here is the link to my Hellaflush Approved Thread. The first SQ to make it on Hellaflush :)
http://fatlace.com/hellaflush/theflushness/on-a-conquest.html
Price:
$7000.[/b] If you dont like it I dont care. This is one of the top cleanest SQs. All the mods that have been done to the car have been tasteful, done well, and NOT hacked.
I may be interested in SOME trades. Nothing FWD! If you have anything you may think Im interested in LMK.
So enough with the none sense...Heres the good stuff :D
http://farm5.static.flickr.com/4029/4579393993_68015420f4_b.jpg
http://farm5.static.flickr.com/4025/4580020236_e77cf027a1_b.jpg
http://farm5.static.flickr.com/4040/4580010962_7672670d15_b.jpg
http://farm5.static.flickr.com/4068/4580003970_529c7af28b_b.jpg
http://farm4.static.flickr.com/3040/4596811561_d132328d00_o.jpg
http://farm2.static.flickr.com/1060/4596811627_4ac545d4e0_o.jpg
http://farm5.static.flickr.com/4026/4596811695_dfe002a570_o.jpg
http://farm2.static.flickr.com/1136/4592207619_67c524f092_b.jpg
http://farm5.static.flickr.com/4002/4427574042_b1aeaa2d37_b.jpg
http://farm3.static.flickr.com/2718/4427573868_41a1817e6e_b.jpg
Heres the old wheel set up and some rolling shots
http://farm5.static.flickr.com/4043/4436210875_e64920295c_b.jpg
http://farm3.static.flickr.com/2754/4436216005_96de1ce99c_b.jpg
http://farm3.static.flickr.com/2761/4436643532_b8c82dfb51_b.jpg
http://farm5.static.flickr.com/4023/4413943527_07a811cc04_b.jpg
Hope you guys enjoy.
-3 wire o2
-MK1 gauge overlays
-1st gen MAS DSM
-ABS Eliminated
-S16G Turbo
-AEM Uego Wideband
Suspension
Wheel Fitment
03-04 Cobras
Front 18x9 -6
Rear 18x10.5 -23
Price:
