View Full Version : sigh
Feelinit18
06-01-2009, 09:13 PM
So I broke a bolt, again. This time is was an extended lugnut from my 18mm spacers. I put my 17ins back on but didnt tighten the lugs fully since I wasnt going to be driving it all weekend. I moved it a foot to put my front wheels on bricks so I could fit a jack under the sideskirt. Went to go tighten the back and the bolt kept on turning.
I usually tighten till it stops but it kept going then snap. Should I replace all of them or just the one that broke?
M.Burroughs
06-01-2009, 09:24 PM
Tis a good question. I'm not totally sure by your explanation as to what happened, but if that one broke, I'd consider replacing them all. Better safe than sorry, especially when you're talking about holding your wheels on.
SeanDub
06-01-2009, 09:25 PM
Just replace the 5, thats what I'd do anyway
Feelinit18
06-01-2009, 09:27 PM
Basically put the wheel on semi tightened the bolts
lowered car back down and it sat for a weekend
went to tighten them and the first one broke off
Thats probably what im going to do
bjh102
06-02-2009, 01:02 AM
Idk bout u guys but it is showing the bolts are old. If u have the $ just replace the bolts on all wheels. Like mike said better safe than sorry
TheNeek
06-02-2009, 09:34 AM
No torque wrench? Bolts stretch, they're designed to do that. What you did was take it past it's yield point, at which time the bolt deforms but is no longer elastic and does so permanently. Over and over again until it stretches so much that it breaks. If you currently don't torque bolts properly, I'd suggest replacing all of them, and at the same time purchasing a proper torque wrench.
Feelinit18
06-02-2009, 10:31 AM
I guess ill be picking up a torque wrench and new bolts. Thanks for the info
Does anyone know how long extended bolts would be for 18mm spacers?
