View Full Version : Coilover question
Stephen
06-01-2009, 06:17 PM
Ok so i can get coils for the front and rear.
Front is pretty much ready to go, so i wont get into that
But the rear ( 2.25 ID springs) Needs perches. Im not sure where to get them.
If they cst too much ill have to pass. :rolleyes
Anyway, experiences/ tips? Id love to switch to coils.
And this is for my e30
Stephen
06-01-2009, 07:00 PM
Did some research, i think i can make it work
dinanm3atl
06-01-2009, 07:05 PM
Pics?
Is this a coilover conversion I am guessing?
M.Burroughs
06-01-2009, 07:32 PM
Call up GC and ask how much they want for just the rear perches. I'd assume not much at all.
Stephen
Yeah, a conversion. heres what i've pieced together so far
Eibach springs, 2.5 ID front, 2.25 rear.
Ireland engineering front perches, then for the rear Irelands bushings ( no adjustability in the rear, only downside)
The other thing E30idea on r3v tossed out as well as some others are ebay perches which are dirt cheap. there arent any up at the moment, but those might get me adjustability back in the rear.
At least at first, im not going to slam it to much, The bilstein sports will be on bumpstops not long after your tucking tire.
Yeah ill try that out, IEs setup is still around 50$, so there might not be much of a difference
M.Burroughs
06-01-2009, 09:45 PM
If you know what drop you're looking for, just spec that spring and run no perch for now, until you can afford one?
Stephen
06-01-2009, 10:14 PM
Possibly. I wanna see what GC says, and see what the fleabay perches look like in terms of quality. Im also weighing my shock options, as im currently on unmolested Billy sports.
Maybe some of you can chime in here, but it sounds like I may bottom out on these if i go too much lower than i am already. Then again, AlpineE30M52 on r3v just has revalved ones, and has got to be at least a full inch below where i'm at.
TheNeek
06-02-2009, 02:39 PM
You're talking about the updated rear shock mounts right? That have a 2.25" coil perch?
Do you have access to a lathe? I made these for my car (still not in use yet):
http://i193.photobucket.com/albums/z45/m42power/rearmount-1.jpg
http://i193.photobucket.com/albums/z45/m42power/rearmountexplode.jpg
http://i193.photobucket.com/albums/z45/m42power/DSCN9021.jpg
http://i193.photobucket.com/albums/z45/m42power/_MG_5869.jpg
http://i193.photobucket.com/albums/z45/m42power/_MG_5873.jpg
http://i193.photobucket.com/albums/z45/m42power/_MG_5965.jpg
http://i193.photobucket.com/albums/z45/m42power/_MG_5964.jpg
http://i193.photobucket.com/albums/z45/m42power/IMG_5968.jpg
http://i193.photobucket.com/albums/z45/m42power/IMG_5967.jpg
I just need to make bushings now.
/thread jack
M.Burroughs
06-02-2009, 03:04 PM
Holy wow.
Stephen
06-02-2009, 03:10 PM
No, but holy reinforcement batman. Nice work.
Im refering to the rear options of keeping the 2.25 ID spring in the rear, whether to just use the srping and bushings, or ebay perches.
GC says they dont sell just hardware, so i may have to get a cheap universla kit and throw away the shit springs, or wait untill the perches only show up on fleabay again.
TheNeek
06-02-2009, 03:17 PM
So you just need adapters (or plates) to accept 2.25" springs?
Stephen
06-02-2009, 05:12 PM
Yep, in the rear. And possibly the front, i havent bought either yet
TheNeek
06-02-2009, 09:25 PM
As you can see... I can cut things on the lathe. What would these pieces cost you if you purchased them? I might be able to make something.
Stephen
06-02-2009, 09:41 PM
Well the cheap ebay ones are about 30$ but id be willing to pay more for ones that wound fit snugly, the ebay ones are more or less universal. I can look around and fint more info though if you like
TheNeek
06-03-2009, 09:24 AM
are they literally a flat disc with a protrusion that centers the 2.25" coil?
Stephen
06-03-2009, 12:49 PM
no, theres a protrusion in the rear so therd have to be a hole in the flat disc
Stephen
06-03-2009, 04:15 PM
So after digging around some, i think im going to use the more or less generic perches, and 6 inch 650/750 eibach springs. Ill probably run an adjuster in the rear unless it looks unsatisfactory. Then ill probably make or have made my own top hats to keep it all in place.
This'll be over billy sports, and i may go to the shorter g60s later allowing me to go lower if need be. Ill have to see what the ride is like
