View Full Version : W210 E-class air ride questions
raffi91
05-15-2010, 04:07 AM
Hows it going guys, just wondering if anyone has seen or owns a w210 on bags. I might be switching back to my 2002 benz E55 for my daily and was thinking about setting up an air ride for it. Any info would be greatly appreciated.
-Raffi
herrakani
05-15-2010, 03:22 PM
Doesn't it come on airsprings stock? At least the w211 comes.
raffi91
05-15-2010, 05:06 PM
Unfortunately it wasn't an option on the w210's. Seems like it would be pretty straight forward since the suspensions consists of separate springs and shocks.
herrakani
05-16-2010, 06:24 AM
I'd assume the w211 bits would fit.
makes it really easy, if you send me some pics of the suspension setup i can build you a system and give u some pricing
raffi91
05-17-2010, 02:41 PM
The w211's have a completely different suspension layout. Also airmatic parts are very expensive.
mpv, thanks for the offer I'll try to get you some pics.
r0nd3L
05-18-2010, 04:48 PM
I'm planning on doing the same to my W124. I wonder how similar the suspensions are setup? W124 has separate springs and shocks as well.
I'm big air ride noob, but I got most of the air management figured out and have idea what to buy. However, can't find any information on air bag sizing and how are they supposed to be mounted.
raffi91
05-18-2010, 06:18 PM
After looking at some diagrams the w124 suspension looks very similar to the w210. The only experience I have had with air ride was when I replaced the factory bags on my 1971 300sel, other then that im also a noob to these set ups. I have a general idea how everything works, but I'm still lost when it comes to mounting a bag and what size to run.
both of you feel free to hit me up oemplush@gmail.com Ive been building air ride kits now for about 4 years....not super complicated........but I can walk you through the basics and not so basics as well as give you an idea of what components will work and what wont for your specific applications
r0nd3L
05-23-2010, 02:38 AM
Well, I took off the spring today and did some measurements of the spring height needed for slammed (bumpstops engaged) as well as desired driving ride height. I think Slam Specialties RE5 would work if it was set to 5.5" driving height in addition to the brackets taking up 3.5". It's hard to explain, so here's a little diagram I drew up. As you can tell, 9" is the desired riding height, so 9-5.5=3.5" worth of spacers/brackets. The only concern is air bag hitting the side of the frame since it's pretty close.
Am I somewhat on the right track with this?
http://www.manizone.com/w124/air/front_air_bag_w124.jpg
http://www.manizone.com/w124/air/w124_front_suspension.jpg
wow you have a ton of clearance in there re5's would work perfect and you might even be able to use the airhouse 2's which are a little bit cheaper. Cup brackets would work perfect and then just using a large washer to bolt it through the bottom so it stays in place and you are all set. Let me know if you want me to get you pricing I get you anything you need
r0nd3L
05-23-2010, 09:02 PM
The frame is pretty close right under the upper spring cup, so that's why I thought RE5 would work pretty well.
Are there pre-made cup brackets close that size? Need approximately 3.5" tall and 4.47" diameter.
yeah thats why i use re5's on the mk4 vw they are the best fit for the rear, i would most likely make them using steel piping/ weld plate on the bottom and notch them for the air line the bottom you might not need a bracket just need to bolt it in to place so it doesnt move around the top you would deff want a cup i was thinking maybe like a 3" height wise, my reasoning is you dont want to limit the amount of drop you will get by using too large of bracket
andrew@openroad
05-26-2010, 12:44 AM
We've done a number of benz suspensions, give me a shout and we can get you setup. It'll be CNC machined stuff, not pipe welded bag brackets.
RE-5's are great on the rear of a MkIV but a Conti-Tech rolling sleeve is far superior to any double bellow rear bag setup.
imo steel is much stronger than aluminum and sleeve bags are good but dont compress nearly as much as the re5's or airhouse 2's which is why ive never had any desire to use those bags
andrew@openroad
05-26-2010, 05:09 PM
IMO a pipe and plate design isn't aesthetically pleasing, welds can break, we use T-6061 Aluminum which is anodized and is not flimsy, the upper bolt threads into the body with a crush nut. Our bags fully compressed are just a little over 4" and 13" fully expanded with air inside them. Don't think thats too shabby, but I could be wrong?
not trying to argue with you.....but there are positives and negatives to both.....imo i really dont care what it looks like its underneath a car that will hopefully be so low to the ground that it would be impossible to see anyway not to mention that it is under the car where its exposed to all kinds of elements so unless the car never sees the ground in the rain or winter the asthetcis dont matter much anyway unless you plan on getting under your car and steam cleaning/ pressure washing the under carriage every summer.
Does machined aluminum look nicer absolutely but it also comes with a much steeper price tag. re5's run about 150 for the set steel cups run about 40 bucks so your looking at 190 for a set vs your sets which I imagine are upwards of the $400 range per set which imo if your running a basic setup that extra 200 is a good portion of your management
I understand that you guys offer a good product but its not always the best product for everyones wants/needs/budget as not everyone can afford to spend 3k on air ride
andrew@openroad
05-26-2010, 08:42 PM
We have kits that cover almost all price points in the market place. We don't just sell BagYard rear bags or fronts. We're a pretty diverse company covering a number of price points and vehicle makes.
Jedidiah
05-26-2010, 08:47 PM
MPV - check your PM box. Thanks.
Ben
Jouns
01-23-2012, 07:33 AM
Let's bring this topic up! I'm thinking of putting bags on my w124 merc, and the suspension parts are same kind as 210. So I'm interested of seeing pictures of bag mountings on w124, w209, w210 or w202.
