View Full Version : FS: 1995 BMW 740iL black/black on FK coilovers
mojocoggo
04-16-2010, 05:28 PM
This car is my daily driver and has never let me down. It has never failed to start and has been perfectly reliable in every aspect. The engine was replaced with a used one about a year ago after a spark plug broke off inside one of the cylinders, ruining the cylinder wall and all four valves on that cylinder. The new engine was completely re-sealed before going in, and was compression tested to rule out the Nikasil issue which plagued certain pre-1996 BMW V8s. Engines effected by this issue usually failed around 60,000 miles due to erosion of the cylinder walls caused by the high sulfur content in American gasoline. Compression is perfect (180-190 PSI) on all cylinders. Both the car and the new engine have been in California since new. Contrary to the "maintenance nightmare" stories usually perpetuated by people who have never owned one of these cars, maintenance costs are not outrageous at all. Yes, it does cost a bit more than normal, for example, the engine requires 8 quarts of oil, and the stock brake rotors are gigantic so they are more expensive. This car has been well-maintained throughout its life, and you can really feel that when driving it. All of the electronics are fully operational and there are no weird glitches or places you have to smack the dashboard to get something to work. The car is located in Temecula, CA and is available for viewing. Send me a PM to make arrangements.
Engine:
-115,000 miles, runs perfect 100% of the time, no smoke or misfires
-Oil changed every 3000 miles with 5W30 Mobil 1 Synthetic
-Replaced water pump (now has metal impeller, not plastic)
-Replaced Radiator
-Replaced timing chain guides
-Replaced oil pump bolts
-Replaced all belts
-Replaced valve cover gaskets
-Replaced spark plugs
-Replaced valley pan gasket
-Replaced all intake manifold gaskets & oil separator valve
-Replaced front oil cyclone separator
-Replaced MAF
Transmission:
-255,000 miles
-Maintained by all previous owners
-Replaced fluid with OEM ESSO LT711-41 fluid (12 quarts at $33 per quart from BMW)
-Replaced filter with OEM FILTRAN unit
-Shifts smoothly, consistently, and quickly every time
-No noises when warm or cold
-Never had "Trans Failsafe Prog" error
Suspension:
-FK Highsport adjustable coilovers
-Power steering works perfectly
-Coilovers are adjustable; 1 inch through 5 inches lower than stock ride height
-Removed self-leveling system the correct way by maintaining fluid circulation, instead of just capping off the lines
-Rubber bushings are worn and should be replaced
-No vibrations or steering wheel shake at any speed, even while hard braking
Brakes:
-Stock lines & calipers
-Front Balo rotors with Akebono Euro Ceramic pads
-Rear ATE PremiumOne slotted rotors with Akebono Euro Ceramic pads
Exterior:
-18" Stern ST-2 wheels 9.5" wide with a 3" lip on all four
-255/35/18 Bridgestone Potenza RE050a Runflat tires
-1999 "Facelift" headlights with 6000K HID lowbeams
-Repainted original color 3 years ago
-2001 style rear lights
Interior:
-A/C and heater both work perfectly
-Replaced blower motor and resistor
-Original black leather
-All instrument cluster pixels work
-MID pixels are 95% working
-AM/FM/Tape & 6-disc CD changer all work perfectly
-No warning lights
-Factory carphone still works if you wanted to activate it
-Cleaned carpet, no stains or rips anywhere
-Factory first aid kit still in-tact
-200 watt 10" Bazooka subwoofer
Issues:
-Lower oil pan gasket has a very small leak, one drop per day
-Three very small dings, one on each front door, one on the back of the trunklid, no paint damage anywhere
-Right rear panel has a shallow dent and scratch (see photo)
-Both front rocker panels are dented on the bottom
-Needs a new speaker in the rear passenger door
-Both rear window regulators should be replaced, windows do not roll down
-Cruise control was removed when the throttle cable bushing broke
$6200 OBO.
http://farm5.static.flickr.com/4011/4600412230_a58bc0e14e_b.jpg
http://farm2.static.flickr.com/1310/4600412126_d030fcabcc_b.jpg
http://farm2.static.flickr.com/1283/4600412028_9cfb632092_b.jpg
http://farm2.static.flickr.com/1131/4600411888_8c6c9c3691_b.jpg
http://farm4.static.flickr.com/3416/4599793399_d28e5ffef9_b.jpg
http://farm4.static.flickr.com/3573/4599793281_8a326e50c0_b.jpg
http://farm2.static.flickr.com/1175/4600411586_f4bed01788_b.jpg
http://farm5.static.flickr.com/4066/4599793067_3fb7ea8b48_b.jpg
http://farm2.static.flickr.com/1250/4600411388_4cbde1354a_b.jpg
http://farm2.static.flickr.com/1364/4600407392_f836f0fb68_b.jpg
http://farm4.static.flickr.com/3349/4599789151_1a8f3e7ed3_b.jpg
http://farm3.static.flickr.com/2596/4028249205_7365d083de_o.jpg
http://farm5.static.flickr.com/4058/4526923078_98c7a6a18e_o.jpg
http://farm5.static.flickr.com/4070/4526291783_b69cea8e48_o.jpg
http://farm5.static.flickr.com/4048/4526576448_20aaf9942b_o.jpg
http://farm5.static.flickr.com/4004/4526576370_0489a609d2_o.jpg
http://farm5.static.flickr.com/4033/4525946017_680ce7082b_o.jpg
http://farm5.static.flickr.com/4008/4525945957_92dc1c1383_o.jpg
http://farm5.static.flickr.com/4055/4526576198_b1e7bcd3e2_o.jpg
http://farm5.static.flickr.com/4067/4525945765_dfcef42d69_o.jpg
http://farm5.static.flickr.com/4004/4525945693_68c214beb4_o.jpg
http://farm5.static.flickr.com/4017/4472756268_a7f9ef45a7_o.jpg
NELSON09
04-16-2010, 06:11 PM
As cliche' as it sounds you really must see this car in person to fully appreciate. Car is crazy low and everything about it just flows. Super Low/Wide. GLWS bud.
NikonJonWtf
04-16-2010, 11:24 PM
You like photoshop huh? Bump for this cool dude!
kramerbuccs24
04-16-2010, 11:26 PM
you have nooooo clue how much i want this. i doubt you want to trade for an 88 MR2 though
bump for one of my favorite cars across the whole interwebs
NELSON09
04-17-2010, 01:07 AM
pffft, ps, plEase. kidds ride is onthefloor, wiiiide and LoW as we all aspire to go (in a full sized sedan too dude) ps nothing. this 7 is the real deal.
Stephen
04-17-2010, 01:17 AM
Ive also seen it in person.
Do want...
CSBolger
04-17-2010, 06:41 AM
Wow. I hope your next car is just as amazing.
Free bump!
scaredofstance
04-17-2010, 06:51 AM
i love your car. makes me wanna cop a E38 so badly
525iT_Feen
04-17-2010, 10:50 AM
Sad to see it go. Whats next?
PHAS3D
04-17-2010, 12:42 PM
so lovely. GLWS!
scaredofstance
04-17-2010, 05:05 PM
oh shit, i just realized htis is a for sale thread, faaaaakkk... its the right price too, but wrong time. :( i would so DD this beast.
schroedin
04-20-2010, 09:13 PM
Free bump!
This, GLWS!
NELSON09
04-21-2010, 11:10 AM
Wednesday bump for you bud.
Ollie
04-21-2010, 11:18 AM
This thing would 100% make it back to NY?
mojocoggo
04-21-2010, 12:24 PM
Absolutely. To be honest though I would rase it an inch if you are gonna drive across the country. You never know what you'll run into.
Also, if this is srs bsns, I can mount some newer tires on it for the long drive.
Puma
04-21-2010, 12:26 PM
Ain't that the truth...
Good luck on the sale mate. My brother has a '95 740i too. This oughta persuade him to start modding it! Expect some PMs this summer if I manage to convince him to slam it haha...
Ollie
04-21-2010, 02:19 PM
Can I ask why you're selling? It's for my buddy but I'd be making the trip with him if he's serious.
mojocoggo
04-21-2010, 03:07 PM
It sounds silly but I'm selling because I can't afford the mods I want to do to it. I had so many big plans for the car (supercharger, 6-speed, baller wheels) but I can't afford to make them all happen anytime soon and ADD has got the best of me.
mojocoggo
04-26-2010, 06:31 PM
Bump for $6750 OBO.
evilstar
04-27-2010, 11:41 PM
God i want this car so bad. you have NO idea how bad. If only I had the money :( I just hope when i do have the money a car and deal like this will be around. :l
mojocoggo
05-01-2010, 09:53 PM
So does anyone want this thing or what? 6500 OBO!
lownslow
05-05-2010, 08:20 PM
why do you have to be all across the country!!!
mojocoggo
05-06-2010, 02:34 PM
So you can have a fun drive back home!
ChrisVRsix
05-10-2010, 02:01 PM
so wicked, GLWS
JSanders
05-10-2010, 02:56 PM
I'm suprised this is still for sale! GLWS, it's one of my favorites or the forum.
jared1988
05-11-2010, 06:41 AM
man if i was in the states... glws
Nevski
05-11-2010, 08:57 AM
Soooo sick
evilstar
06-06-2010, 12:15 AM
Saw this at bimmer fest and the thing is sooo sick. one of the lowest cars there. god i wish i had the money to buy this.
PS: OP i was the guy who wanted to do a photoshoot with the car and gave you a card let me know if your interested while you still have it.
Mateen9
06-07-2010, 08:37 AM
Off topic. How pleased are you with the Highsports? I'm on the fence between these and a different set, glws!
evilstar
06-24-2010, 12:48 AM
Free bump for a very sick car.
feia0303
06-24-2010, 02:01 AM
free bump if i sell the e46 soon :shifty
shogunner
06-28-2010, 02:15 PM
sick... it'll sell
Vito99
06-28-2010, 02:25 PM
i live in boston and im highly interested in this thing....is shipping in option ??
Eriks
07-08-2010, 12:51 PM
free bump for one of best looking e38!!
MMMPR3S
07-14-2010, 07:02 PM
Damn super clean! GLWS!
Matth3w
08-01-2010, 07:40 PM
still for sale?
Matth3w
08-01-2010, 07:42 PM
n/m, just saw that it was sold on BF
