View Full Version : spacers...
bataangpinoy
07-13-2009, 11:17 PM
i have an e30, running 15 inch bbs rz, et-24, aka euroweaves. can someon help me with my measuremants to make em flush?
Royal_T
07-13-2009, 11:48 PM
15x?...need to know
bataangpinoy
07-14-2009, 12:00 AM
oops, 15x7. forgot to type that....
Stephen
07-14-2009, 12:17 AM
20mm would be pretty agressive, but might work out for you if your tires arent big
bataangpinoy
07-14-2009, 12:22 AM
tires are 195/55. thats a larger sidewall and slight stretch. i was thinking like 5mm up front and 10 mm in the rear. but that requires rolling my the fenders. i dont know how to...
Stephen
07-14-2009, 12:24 AM
5 and 10 wont be flush but theyll look good
SeanDub
07-14-2009, 12:53 AM
-24? jesus.
bataangpinoy
07-14-2009, 12:56 AM
its actually plus 24. the - is merely a hypen lol
SeanDub
07-14-2009, 01:03 AM
This makes much more sense lol
Digitalwave
07-16-2009, 09:19 AM
I think 7" wide ET-24 would actually fit an E30, since my friend runs 16x9" ET0 in the rear. It would look silly, however.
bataangpinoy
07-16-2009, 10:28 AM
hahah i bet it would...
i still want to make these flush
Digitalwave
07-16-2009, 10:30 AM
Well his 16x9's are flush so maybe you need 40mm spacers?
bataangpinoy
07-16-2009, 10:52 AM
well kamotors on e30tech runs 20mm all around on his bottlecaps(flush). those are like et 30.
he said he could go another 5 mm in the back.
so i need 10 mm up front and 15 in the back?
i see it as this. et30-20mm=et10
et30-et24= 6mm
so to get to et10 on my euro weaves, i need to get 14 mm spacers. they dont make those, so should i run 10mm spacers? my math is prolly fuxxored
Digitalwave
07-16-2009, 10:56 AM
Bottlecaps are ET35. So with 20mm spacers = ET15. However, bottlecaps are 6" wide and 6" ET15 is NO WHERE even CLOSE to being flush on an E30.
Digitalwave
07-16-2009, 11:00 AM
Here is an example for you. This is 16x9" ET0 on an E30 with stock fenders. It's flush or slightly poked. The equivalent with a 7" wide wheel is ET-25! As in negative offset. You would need 44mm spacers to match his flushness.
http://i78.photobucket.com/albums/j96/airbrain/MSP_0100.jpg
bataangpinoy
07-16-2009, 11:16 AM
holy sh!t. yea 44mm spacers are ridiculous. would pics help?
bataangpinoy
07-16-2009, 11:19 AM
you can kinda see how close(or far) wy tires are to my fender lip.
http://i702.photobucket.com/albums/ww21/bataangpinoy/e30tech%20r3vlimited/e304.jpg
Stephen
07-20-2009, 02:40 AM
16x9 et0 is going to be only slightly poked in the rear. In the front however, itll poke, to much for my taste. Sportmax 002s poke at et0, and theyre only 8" wide.
20 and 25 would be reasonable to find.. they wouldn't necessarily be flush but they'd be alot better.
People use that spacer combo alot on stock weaves, with 6.5 width and et30, and they arent flush but they look good.
bataangpinoy
08-01-2009, 12:10 AM
they look like unspaced euro weaves.
