Well, today whilst the wife and I took the kiddo's to see a movie somebody was nice enough to run into our 2007 Toyota Camry. It left a nice dent on the left side fender, right on the wheel arch.
Fender Fix
To start off the project right you need to break out the tool box and get the tools prepped that your going to use. In this case we needed a few things.
1 ratchet
1 10mm socket
1 6" Long extension
1 3" Long extension
1 body panel removal tool
1 rubber mallet
1 rubber sanding block
1 knife
1 phillips screw driver.
1 jack
2 jack stands
2 non marring wedgesAttached Files
Now then from here Lets get that fender aligned....
loosen up all the bolts holding it in place
four on top.
one on bottom and one behind the door.
once you loosen them up drive that wedge into the space between the door and fender till you get the right spacing,
then tighten it up starting from the bottom to the topAttached Files
