Negative/Low off set wheels?
  • Negative/Low off set wheels?
    Yo!
    I have 9x16 ET15 Borbet As
    I still have insufficient poke at the back, but at the front the tie rods rub very mildly against the back of the barrels.
    Being a noob, do I just get spacers, or since I'm being tempted anyway, do I get low/negative offset wheels?
    Will I really find 5x112 at negative offsets?
    As you can see, more lows and pokes needed. Help me!
    1986 500 SEC
    Mods, please move to wheels forum...I'm a douchebag
    Thank you
    1986 500 SEC
      Lols
      Instagram @wickedweiss
        spacers work for the front, also you could shave down the backpad of the rear wheels so they dont poke as much. for wheel options, it just depends how deep your pockets are. Theres tons of wheels in the classifieds on here or vortex. Not as many options for 16's in 5x112 but if you want to run wobble bolts you could buy 5x114.3 wheels too
          So some 5mm on the front would work.
          For the rears I want more poke. I'm currently investigating some 17x9 fronts and 17x10 rears which should do the job!
          Are wobble bolts safe? Sound retarded
          1986 500 SEC
            wobble bolts are no problem. perfectly safe.
