View Full Version : FS OZ fittipaldi fittistars... BIG LIPS
Tropicana
12-15-2009, 09:34 AM
17x8
et 37
17x9.5
et 31
They are the only set to my knowledge that are around and are 5x114.3
the front lips are 2.5" lips...
the rears are 4.5" lips purchased from tuner shop at $326 a piece (they havent even had tires mounted on them yet)
the bolts are oz bolts that have been hand polished.
I have 5 center caps for them and will include the center cap tool as well.
centers are completely hand polished with flat black windows
http://i33.photobucket.com/albums/d64/CoreyMar4/September-04_0708.jpg
http://i33.photobucket.com/albums/d64/CoreyMar4/September-08_1700.jpg
starting price is 2600
00bmw323
12-15-2009, 10:55 AM
love these wheels!
dinanm3atl
12-15-2009, 11:15 AM
Damn. Wish they were 5x120...
Tropicana
12-15-2009, 12:13 PM
thats what they make adapters for
dinanm3atl
12-15-2009, 05:11 PM
I am well aware that they make adapters. 17x11 ET37 with a 25mm adapter....
17x11 et12? No thanks. I run a 17x10 et33 with a 255.40.17 and it already rubs(and is stretched) backing out of the driveway and not interested in running some sort of massively stretched tire.
Dubmd
12-16-2009, 11:28 AM
lame wheels:devillook
jk what size barrels?
i need to get some smaller ones cuz my offsets way to high:rolleyes
edit: Fack i cant stop looking at these!!
i need to build mine
Tropicana
12-16-2009, 06:58 PM
6.5 in the front, and 7.5 in the back for barrell size
Tropicana
01-06-2010, 10:47 AM
bump for new lips out back
Are these offsets before or after the lips? 4.5" rear lips with a final ET37 would have to had been 60+ ET rear before.
Also, you said they're 7.5" barrels rear? 7.5 + 4.5 = 12", not 11" and that's if they are face mount/reverse face mount.
Ollie
01-06-2010, 11:25 AM
+1 doesnt make sense...
Tropicana
01-06-2010, 12:03 PM
the face says et37.. i was under the impression the offset stays the same when just a lip is changed, i thought the offset is determined by the center...
it was either 11 or 12 depending on how you measure...
Offset is determinant of the backspacing and center line. Since the centerline moves as you push out the exterior side (lip side), it will lower the overall offset.
To measure wheels' widths properly, it is measured by the inner bead to the inner bead.
http://www.stanceworks.com/forums/showthread.php?t=3145
Tropicana
01-06-2010, 12:19 PM
inner bead to inner bead was 11... if my math is right it should be 9.5 now
With the 4.5" lips? Aren't these wheels sandwich mounted? If so, that has a 1/2" face in between the parts...
What do you mean by 9.5? Width? Offset?
Tropicana
01-06-2010, 01:26 PM
there going to be sold now with 3" lips... yes they are sandwich mounted
3" lip + .5" face + 7.5" Barrel = 11" now.
Tropicana
01-06-2010, 01:43 PM
i got to measure the barrel again, that doesnt seem right... they were definitely 11" inner lip to inner lip with the 4.5 lips
Tropicana
01-07-2010, 12:00 PM
rear offset is et 31 after the new 3 inch lip
rear offset is et 32 after the new 3 inch lip
What size lip was on there on the beginning when it was ET37?
flossz
01-07-2010, 12:08 PM
bump for Dave, these wheels will be alot more user friendly with the 3" lip.
Tropicana
01-07-2010, 12:14 PM
2.5"
KarlSpackler
01-08-2010, 10:41 PM
You lose 12.7mm of offset for every 1" wider lip you add.
Figure it out
Tropicana
01-10-2010, 09:54 AM
Figure it out
your a day late and dollar short.
+.5 = 6.35mm
37mm - 6.35mm
=30.65mm
so round up and that brind its it to et 31.
as it updated 3 posted above you and on the original post.
