View Full Version : E30 momo steering wheel question
TheStig
12-14-2009, 11:14 AM
Ok, I got a 91 318is, I'm getting a Momo wheel, I've heard alot of different things about the hub adapter. Does anybody know the correct hub to get? or at least if the steering wheels spacer is needed? if it is, where can I order one besides BMW? Thanks for any help.
bataangpinoy
12-20-2009, 06:06 PM
any e30 mom hub will fit. as far as the air bag thingy, it will just throw on the light so pull the srs lightbulb out when you put you hub on.
TheStig
12-25-2009, 10:35 AM
Ok thanks, do you know anything about the spacer needed to fully cover the splines, so its not loose when fully tightened down?
bataangpinoy
12-25-2009, 06:55 PM
ive never heard of that problem on any ofthe e30 boards im on, can you show me a pic of shat you mean? your name for the part my be called something else in e30 terms.
Oscar
12-25-2009, 07:52 PM
I have a hub with Momo bolt pattern and it fit just fine. Pulled the old wheel off, installed hub, then put new wheel on. Been driving this way for a few months with no problems.
TheStig
12-26-2009, 07:36 AM
I dont have any pics. From what I've gathered on the E30 boards, its called a steering wheel spacer.??
What year E30 do you have? Mine is a 91 with an airbag, I heard that the splines are thicker on the airbag column than the non airbag column. Therefore the spacer is needed, to take up the extra slack that would be there when the nut is fully tightened down.
87e30
12-27-2009, 09:35 PM
I have a non-airbag model so no problems. However, if I'm understanding correctly I don't see why you couldn't use some washers...
Hartgeh27
12-27-2009, 10:20 PM
Just get the spacer from a non air bag car at a junkyard. quick and easy fix.
TheStig
12-28-2009, 09:00 AM
I think its kinda hard to find washers with that big of a center.
TheStig
12-28-2009, 09:01 AM
Ehh fuck it, ill just put it on the M3 :)
Hartgeh27
12-28-2009, 08:31 PM
lol well thats one use for it
TheStig
12-30-2009, 07:07 PM
Haha yeah, why not??
Hartgeh27
12-30-2009, 08:50 PM
Which Momo is it?
TheStig
01-01-2010, 10:22 PM
Mod 07
TheStig
01-04-2010, 03:24 PM
Ok, so the hub doesnt fit the E36 either, its a 98.5 and it was made in the wrong damn month. The splines are different and Momo doesnt make the right hub for it. Any suggestions??
Hartgeh27
01-04-2010, 08:24 PM
give it to me
TheStig
01-04-2010, 09:04 PM
give it to me
I'd really rather just keep it, and put it in haha
Hartgeh27
01-05-2010, 10:29 AM
ok but to put it in the e30 all u need is the spacers. if u want i cann go look to see if i can get u some. where r u located.
TheStig
01-05-2010, 04:41 PM
Im on LI NY. but I think I found a deal on something else, I might just return it and go with another option.
bataangpinoy
01-06-2010, 06:30 PM
http://www.e30tech.com/forum/showthread.php?t=87501
here you are stigy.
bataangpinoy
01-06-2010, 06:34 PM
http://e30tech.com/forum/showthread.php?t=71838
TheStig
01-06-2010, 08:26 PM
Ooooo thanks for that man, but I just returned the hub and wheel. Didn't have the right hub for it anyway. So Im getting a fender roller instead. :)
