View Full Version : drivers side window problem, car is SOAKED
TheStig
06-19-2009, 06:38 AM
I'm not sure if this is a common problem or not, but my window has rolled itself down about an inch and a half last night, and of cousre this has to happen when it POURED for 4 hours. So I dried my seat, drove home, parked the car. I walk outside thismorning, and it happened again. So I'm at work right now worrying its gonna happen again, because there is another chance of showers today, and I can't be the same place my car is if it does happen again. Any help would be greatly appreciated.
dinanm3atl
06-19-2009, 10:38 AM
Something is up with the window regulator and it is having trouble 'holding' the window.
Does the window work properly besides it randomly dropping down by itself?
TheStig
06-19-2009, 12:43 PM
Yes, last night was the first time it has ever given me a problem. Now I have been at work since 630 thismorning, I keep checking on it, and it seems to be fine now... I just wanna know what was wrong with it so it doesn't happen again.
dinanm3atl
06-19-2009, 01:33 PM
Either the regulator or the motor is failing or one of the mounts(should be rivets on your e36) are loose and thus letting the window fall a little bit.
One of those would be my first place to start. E36 is notorious for window problems.
TheStig
06-19-2009, 02:54 PM
Damn, I thought I got rid of thoes problems when I sold my MK3s haha. Thanks for the help man, Im gonna try to tackle that this weekend if the weather is nice.
dinanm3atl
06-19-2009, 02:59 PM
No Problemo good sir!
Just pull the door panel off and play with the window and see if you notice anything. Will probably have to drop a window regulator into that biotch.
TheStig
06-19-2009, 06:26 PM
From my VW experience, that doesnt sound like a cheap or easy fix :(
dinanm3atl
06-19-2009, 06:28 PM
Window regulator is about 100 bucks. Motor is about 200 bucks.
More than likely it is one of those two parts.
NegativeCamber
06-22-2009, 02:56 AM
welcome to the world of the e36 coupe. they are all plagued with this issue.
JSanders
07-23-2009, 12:14 PM
In a E46, you can fix it with a ziptie and it will last forever, granted you dont let it destroy itself before you try to fix it.
Is there not a quick fix for the e36?
dinanm3atl
07-23-2009, 04:26 PM
Not that I know of.
EThirtySicks
07-25-2009, 09:08 PM
E36s have garbage window problems. Oftentimes it's the window regulator crapping out.
WhiteStripes
10-22-2009, 12:09 AM
My neighbor and I were talking about Bimmers and he said his cousin has been through like 3 sets of regulators in the 12 years he's had his 325i lol.
FluidMotorUnion
10-22-2009, 02:17 PM
Always Check your door switch first, a faulty or misaligned door switch will cause the window to go up and down randomly. a bit late but good advice for any one checking this.
