Hey guys! I was lookin at my spare set of struts thinkin bout goin lower next spring and obviously my shock's are the biggest limiting factor at this point, I had an idea however. My struts have the upper spring mount and the strut bearing that actually bolts to the car (pictured below) on top. The thing is the strut bearing mount is fairly large/tall, and I could gain prob half an inch lower if I made one that was flatter/thinner. Then I realized I need to learn more about my suspension because I assume that just a flat plate of metal with the proper holes drilled wouldn't help because obviously that bushing like center and the bearing are there for a reason. So I figured Id ask y'all if anyone is a suspension master and could look at this pic and explain to me what im dealing with.
Thanks!
Alex
Actually found basically what I was thinking bout, http://www.grandprix.net/forum/ubbth...er=3145&page=2
he cut out the middle of his old mount and welded in a 'bump mount' which I have never heard of, and my other though is wouldnt a setup like this make it harder for the strut to rotate? I know he put the thrust bearings under the spring, but still..
Thanks!
Alex
