View Full Version : Spraying mesh wheels??? HALP
KarlSpackler
11-29-2009, 08:15 PM
So, I have a set of style 5's I am re-doing to run as a spare set of wheels.
Normally, EVERY time I have ever done a set of RSs I have had them powder coated. Well, these are cheap so I was going as cheap as possible.
So what do I do, go get some rattle cans. Well, with the tight mesh of the Style 5's it is IMPOSSIBLE to get paint into grooves without overspraying which then runs.
So, now I have a set of wheel faces that look like dick up close. I honestly dont really care too much as these dont mean a whole lot to me but that's not how I roll.
Anyone have some advise?
bataangpinoy
11-29-2009, 08:22 PM
soda blast em and rattle can then bitches
00bmw323
11-29-2009, 08:24 PM
what i did is
sand as best as you can..clean....sand...clean again then 2 coats of primer..then let them dry overnight...then base coat (3-5) times and what i should of done is clear coat...but try flipping the center and spray from behind also so you get better coverage.
tivs31
11-29-2009, 08:31 PM
to get the right coverage your going to have to do alot of passes on them, most mesh wheels are pretty hard to do, but if you do 4-5 light coats it should cover everything. If your getting runs it means your spraying too close and applying too much paint, try doing lighter coats and more passes
SeanDub
11-30-2009, 12:00 AM
They are not impossible. Just take your time and lay a lot of coats.
Stephen
11-30-2009, 12:23 AM
Go from different angles to, and lightly
E36HB
11-30-2009, 12:30 AM
Spray from the back also!!!
Effin' Euro
11-30-2009, 01:56 AM
:eyebrows :rofl
verrrrry light coats from all angles my friend. good luck on round 2.
balleur
11-30-2009, 03:31 PM
or you can sand plast em and powder coat em
honestly with time and effort on sanding and amount of money spent on rattle cans youd prob be preety close to how much it would cost to powder coat.
B Rod
11-30-2009, 03:55 PM
Bimmerteck
11-30-2009, 04:07 PM
1. lightly heat the centers, not 500 degrees or anything the lowest setting in your oven will do.
2. soak the paint cans in warm water for 20 min. before you spray. (standing up in a sink so you don't get water in the tips)
3. hang the centers, and be able to rotate them slowly as you spray.
The paint will mix better, dry faster, and coat more evenly.
Erik
JeShUa
11-30-2009, 04:29 PM
Word. Paint shouldn't be running.
The outer lip is covered so I'd hang them by a rivet hole. I hung my motorcycle parts by the holes they connect at lol.. or just strung them through so there was no unpainted area.
frey328is
12-01-2009, 12:06 AM
When I did mine I did lots of light coats from different angles, no running.
KarlSpackler
12-01-2009, 01:26 PM
Like I said, these didnt mean much to me and I did them quick.
I already fucked them up so I will roll with what I got.
When I re-do them, I will do them properly.
The Green Grundel
12-01-2009, 01:50 PM
If you can, hang them from a tree or something strung up like a hammock. This is allow you to hit them from all different angles. Just mount the string to parts that aren't shown OR just move the ties when it dries and put them somewhere else.
