View Full Version : Looking for more power in my 635CSi.
NicMOSH
12-13-2011, 02:26 PM
Basically what the title says. Anyone know turbo kits or easy swaps into my car? Thanks in advance.
theseeker411
12-20-2011, 08:15 AM
Tubocharging Dynamics and Miller Performance both make turbo kits. Cartech, Callaway, and Dinan have all made turbo kits in the past as well, and they pop up on ebay from time to time.
M & S50/52s have been swapped in, though I wouldn't call it "easy." Search mye28.com for info on those swaps, as the e28 and e24 are basically the same car.
NicMOSH
01-03-2012, 11:41 AM
Oh I forgot to mention.. My car has the full Split Second MAF upgrade and I'm unsure if it will effect my setup. I will most likely be going with a Stage 1 TD kit.
Snappy
01-05-2012, 01:44 AM
S50 swap, guy.
Kotofey
01-06-2012, 06:11 PM
I have tried buy celebrex (http://celebrexpill.com/) before and must say that brand cialis (http://brandcialismed.com/) causes less side effects though. I had terrible headache with Viagra which made sex impossible sometimes. With cialis (http://brandcialismed.com/) I forgot about it. I would recommend it to anybody who has similar problems and this drug is above all praises.”
LJ851
01-13-2012, 10:11 PM
S50 swap, guy.
M30 turbo > S50 swap by a wide margin.
Jorge
01-14-2012, 09:04 AM
Make a 650i? V12 goodness.
AcceptFan
01-14-2012, 02:04 PM
Spam
Bra1nl3ss
01-29-2012, 04:20 PM
Turboed the m30 in your car will easily hold 400 hp with stock internals, bigger injectors and a proper tune. You could also source the turbo parts and DME from a e23 745i if you want to go the oem route. Only 252 hp though
Masonbarnard
01-29-2012, 06:44 PM
strongly agree
Psyka
03-19-2012, 12:08 PM
Turbo charge , Bigger injectors , forged pistons , there are a lot of ways ! Depends on ya money !
Hibbard
05-22-2012, 11:18 AM
m30's are basically a factory turbo charged engine that bmw forgot to add a turbo to(besides the euro 745). Strong iron block, lower compression, prettty bullet proof internals. They are also plentiful. I would just put some upgraded head studs and head gasket and boost it till it blows up, then replace with another m30 for a few hundred bucks.
CamMaster
05-22-2012, 01:30 PM
boost it and make a 645...
or swap in an m60b40!
make a 640...
650 would be dope!!
