Is it ok if the center portion of the bottom of the bag isn't supported? I have to cut off the spring-centering nipple and weld a plate under the spring perch, but after that nipple goes, there will be nothing touching the center portion of the lower bag fixture.
Is it ok if the bag wrinkles or folds over itself when all the way down, or should I make my brackets and set my shock bump stops so that it never comrpesses past 5 7/8" or so (when the bag starts touching the perch (or ground, in this case, while doing measurements...
Is it ok if the top of the bag is slightly askew? Due to the body frame width, the bag will have to be shifted in 1/4" to 1/2" in either direction for the air line nipple.
Thanks!
Thanks!
