View Full Version : Shorter Springs for A3
N.E.V
11-21-2009, 11:07 PM
Hey guys,
I have a Audi A3 Q and looking to go lower,
These are the coilovers I have now: http://shop.achtuning.com/index.asp?PageAction=VIEWPROD&ProdID=1300
They are threaded down all the way but I would like to go about an inch, to a inch 1/2 lower. From what I have read it sounds like the easiest way is to get shorter springs and take out the locking threads? If so, what springs would you guys reccomend? I have emailed GC, KONI, and Stasis, but haven't got a solid answer, so i thought i would turn to the experts :)
Here is where she sits currently:
http://i692.photobucket.com/albums/vv288/3_is_1/AudiA3beachnonving.jpg
Thanks for the help,
Nev
LuckyBoyOne3
11-22-2009, 01:13 AM
Hey another PNW ride! I like it.
Mark Ostrowski
12-24-2009, 10:57 PM
you take out the helper springs yet?
*Edit: damn, i guess you don't have helper springs? you could always cut your springs yourself for a quick fix..
Mike Migs
01-25-2010, 06:54 PM
For the front like stated above you could cut the top coil off on the springs.. and the rear you can buy a shorter Race springs.. PM me and I will see what i can do for you..
Mike
wheelfetish
01-25-2010, 10:04 PM
I want a A3 so bad :(
Anyway, if you do decide to cut the springs, do it in steps. I wouldn't recommend cutting a whole 2 coils off, just a few inches off the top should do. Take about 3-6 in off the top, test it, then step back and think if you want to go any lower. Repeat until you achieve the height your looking for.
Remember, a whole coil doesn't mean 1in lower ;)
Mentosman42
01-28-2010, 07:46 AM
yay another A3'r, u running 19's?
just wondering cause i am running Koni adjustables(not stasis but they should be basically the same thing) and i can like literally drop it to the ground with them.
but yeah, you could cut the springs up front and remove the collar in the back, or if u wanted to spend the money you could get a different set of springs, im sure they have more options as far as height and spring rate.
vortex has a good A3 community if u want more answers.
