E36 coilover fitment advice
  • E36 coilover fitment advice
    Am going to tackle the task of installing new coilovers on the weekend,
    Now i have replaced coilovers before but not on a E36.
    Im not using camber plates in the install but the original mounts
    what do i reuse with fitting?
    I have read that you have to reuse certain washers etc
    if there is a previous post on this subject please let me know would be a great help.
    Cheers
    the top washers you need to reuse, or else when you are gonna tighten the nut on the shock, it will clamp down on the bearing inside the top hat, making the hat stuck in one position. if done the right way, (keeping the right washers) you will be able to twirl the top mount around and around.
    good luck with your project. (normally coil overs have a manual witch says what to use and not use.)
    -Instagram@jdjurhuus
    Stretchsaurus and Pokemon.
      Burn the witch!
        Originally posted by stance4sissies View Post
        Burn the witch!
        get of my back, English is not my first language.
        im only here to help the man out, not to be correct on grammar.
        go somewhere else if you wanna point grammar mistakes out.
