View Full Version : Dad left his bikes to the kids.
MaxBell
09-13-2011, 11:07 AM
I'm the youngest son, and my older brothers and sister took all his other nice motorbikes. There were three old bikes left, none of while actually are drivable.
I've moved them over to my little garage and have some free time.
PROBLEM: I know about cars, but not about bikes.
SOLUTION: Let me know what you can see on these three things.
Bike #1 A 1985ish (88?) Kawasaki GPZ 550
Mom says the bike starts and runs fine, but she can't find the key for it. I looked on eBay but I'm not sure of the year or anything, so I don't want to jump on an ignition until I know more. It's a great looking bike, just needs some serious cleaning and a way to get it started.
Kawasaki GPZ 550 (http://clinteastwood.imgur.com/kawasaki_gpz_550#dQ8JH)
Bike #2 Yamaha dirt bike
I know nothing about this thing, other then it is missing something big in the center of it. It was dad's dirt bike that he raced around a bit when I was younger. He fell off it once I remember and broke his arm, it was manly.
Can anyone see what it is that is needed in the middle of it there? There's a hole at the back of the block (the thing with heat fins) that hisses when I moved the kick starter. There is a gas line coming down from the tank (through a fuel cut off valve). Towards the tail is a plastic box thing with an opening aimed down into this space.
The Yamaha Dirt Bike (http://clinteastwood.imgur.com/yamaha_dirt_bike#1xXIr)
Bike #3 Yamaha parts bike of some sort
This was a parts bike, but for what other bike I have no idea. I called my brothers and sister and they didn't know anything about it. There is only this and the Yamaha dirt bike, no other Yamaha bikes around. This one has a carb, but no fuel tank or headlight
Shitty Parts Bike (http://clinteastwood.imgur.com/shitty_parts_bike#9ue4I)
Any help at all is appreciated.
RXTurner21
09-13-2011, 09:38 PM
could the hole in the block be for a spark plug? only thing I can really think of.
FunfGang
09-13-2011, 09:48 PM
For the dirt bike... Most motors need a way to get fuel in the engine, dirt bikes use a carb...
You couldn't tell by looking at the parts bike? That theres a large piece missing...
fatboi567
09-15-2011, 06:25 PM
Thing needed would be a carb, the black box is more than likely the air box and filter......im guessing it would be a 125cc so I would take the carb from the parts bike and bolt it onto the back of the cylinder (thing with the fins) then squirt some fuel into this with the throttle open. Get a pipe and attatch the airbox tube to the carb, attatch the fuel pipe to the top of the carb (probably be a breather on the bottom), put a new spark plug in it and give it a few kicks....there are not many things to go wrong with this type of engine so as long as its sparking and is getting fuel then it should run :)
The GPZ will be roughly an 88-92 on the year, this should help you to find an ignition system for it.
FunfGang
09-16-2011, 02:12 PM
^ Listen to him.
MaxBell
01-11-2012, 01:15 PM
Just thought I'd update!
The GPz550 runs and drives and I spent last summer/fall on it. The other bikes are still works in progress.
