View Full Version : air line set up
deOtherhalf
09-02-2011, 02:32 PM
Hello everyone, I wanted to ask, how did you set up your air line from front to the rear into the tank. Outside or inside of the vehicle? Which one would you suggest for best easy access and such. Is everyone running regular plastic lines with brass fittings?
Please share, Thanks :D
Schnitz
09-06-2011, 09:18 PM
Outside the vehicle for me.
Regular plastic air line with brass & PTC fittings.
deOtherhalf
09-07-2011, 12:36 AM
Thanks, took awhile for someone to reply
Schnitz
09-09-2011, 07:57 AM
airsociety forums have a little more traffic as far as air goes
hinrichs
09-09-2011, 08:13 AM
i always run myne outside of the car to make everything easier, inside for me would be nice, but getting to a bad line would take way to much time
deOtherhalf
09-09-2011, 10:38 AM
yeah. Sounds like I will be doing mine outside as well
Capone
10-10-2011, 07:12 AM
Mine are outside using DOT 1/2" airline and DOT ptc fittings. I also used stainless steel hardlines and stainless steel swagelok fittings for my trunk setup.
Yakuza Racer
10-18-2011, 01:25 AM
thanks for the tip
Francois Dillinger
10-18-2011, 03:52 AM
i wouldn't even think of doing air line inside the car unless you only ran 1/4". even then, would be a pain in the dick and potentially visible under the carpet. just run them along your brake lines.
