View Full Version : starter problem?
boxedout
08-22-2011, 02:10 PM
i have a 88 civic sedan dx and yesterday i planned on doing a straight pipe from my cat-back but realized that my welder was broken so i decided to just bring my car to a local shop and they brought it out the back with no problem... however, this morning i went to start the car and it was turning over very slowly, so i checked the battery acid and the battery was nearly dead as a door nail. so i went out a bought a new battery, but now, it's not even turning over as if the battery is dead, but my lights and everything else work when the key is turned on. does anyone know what could be the problem? thanks
StatusRacing
08-22-2011, 02:58 PM
1) Check fuses
2) Try using a screwdriver and bridging the contacts on your starter solenoid. Make sure the car is in neutral or park though lol. Don't run yourself over ;)
boxedout
08-22-2011, 04:15 PM
the fuses are okay .. and the contacts of the starter solenoid seem okay. i'm thinking making the solenoid just went bad. when i turn the key i do hear a click, just one click.. then nothing else.
markdett
08-23-2011, 05:51 AM
Auto or manual? If auto can be your neutral switch.
Best thing to do is check power at the starter motor. The main terminal you should get battery power, the other one you should get battery power when the ignition is on. Hope that helps :)
Also immobilised?
boxedout
08-24-2011, 06:49 PM
got it all fixed... took out the start and it was fried so i just finished putting in a new starter, its all good now. thanks for the help
