View Full Version : E36 Coupe Or Sedan?
Vegas_Sirk
10-23-2009, 05:42 PM
Im thinking of picking up a E36 for my next project and to build as a dedicated track car. I have decided to do the LS1 swap as for classing purposed in time attack its the best way to make the most power and not get bumped up a class.
My question is are there and benifits to buying a coupe over the sedan? I find a lot more used sedan for cheap in the paper then coupes. Is the shorter wheelbase a benifit on the coupe? or are the wheel bases close to the same? Also any major weight differences? How about after market? I know they offered the M in both the coupe and sedan so I know there is aero for both.
I would love to hear some feedback on this.
SeanDub
10-23-2009, 05:47 PM
From what I understand they weigh close to the exact same
VALMONT
10-23-2009, 05:48 PM
sedan.
Vegas_Sirk
10-23-2009, 05:51 PM
sedan.
Why?
SeanDub
10-23-2009, 05:55 PM
Let me get my friend to help you out. He's a track guy, I'm sure he'll have some good input.
Stephen
10-23-2009, 06:03 PM
Dunno bout an e36, but for e30s the wheelbase is the same, a weight difference of only about 55lbs, and the kicker, the 4 doors are more rigid. I know that is the case with the e36 sedan as well.
JSanders
10-23-2009, 06:07 PM
E46 sedans are more rigid as well.
VALMONT
10-23-2009, 06:14 PM
truth. i have a coupe and drove my sisters sedan, and i liked the handling of the sedan better. :(
i only got the coupe for the factory colored mouldings and not having that damn B-pillar blocking my view.
TRiCC
10-24-2009, 12:10 AM
sedans have an extra pillar where the door hinges go in, meaning more rigid and less flexing in the chassis, sedan and coupes on paper weight exactly the same. and plus fo do's fo mo ho's :]
Jamil
10-24-2009, 01:40 AM
the truth!! sedan>coupe unfortunately.
Edirty6
10-24-2009, 02:35 PM
^^^what he said....4dr>2dr
Vegas_Sirk
10-26-2009, 04:03 PM
Ok thanks guys for all the insight.
What about parts wise? any problems getting parts for the Sedan??? over the Coupe ???
Vegas_Sirk
10-26-2009, 04:06 PM
Also on the E36 and years that are better then others???
Digitalwave
10-26-2009, 08:13 PM
Everything is basically the same on both, except body panels.
Geoff.T
10-28-2009, 12:55 PM
Just get a E36 M3 Sedan. The Sedans feel slightly more rigid than the coupes. Also, the head room is better in the sedan. It makes a huge difference for helmet clearance. Lastly, the sedan is a easier car to service when a cage is in it.
I've had 2 e36 coupes before my sedan. Trust me, the sedan is the better way to go.
southpaw
11-01-2009, 02:08 PM
The man has spoken.
1985zcar
11-01-2009, 02:13 PM
I've always preferred the looks of the Coupe over the Sedan...even though Mick and me picked up a sedan as a project, lol was too good of a deal to pass.
I suppose it depends on what you wanna do though, if you're gonna be carrying people, the sedan is obviously more practical, haha
Also, the year thing depends on what you wanna do...newer is better so far as less worn out parts, nicer options, etc. but if you wanna build it for boost or swap the engine etc, and you have to deal with emission laws, then you'll want an OBD1 car.
Look out for subframe mounting points on the body wearing out. Our project car had this happen, which is why we got it for so cheap, as it's currently undrivable, the front 2 mounting points where the subframe bolts to the body ripped out, no beuno.
Digitalwave
11-01-2009, 07:13 PM
He said it's going to be a dedicated track car so I am pretty sure that looks and/or the ability to carry people don't matter at all.
Tony Soprano
11-01-2009, 07:21 PM
this. said by the guy with the sickest E36 sedan on the interwebz.
Vegas_Sirk
11-02-2009, 01:53 PM
Thanks guys!
Formula E
11-04-2009, 11:05 PM
Yeah but his point about buying obd1 for a track/swapped car was dead on, so that rules out the sedan imo. Get 95 coupe and call it a day.
Chowbow
11-05-2009, 01:30 PM
Sedan, but that has been decided. Another thing to consider is to get a car without fold down back seats if you can. Also makes the car slightly more rigid, along with the solid B-pillars of the sedan.
Nate325
12-07-2009, 05:07 PM
If you get a sedan, try and find an early 97, they weighed less then the 98's and 99's, But that was because of the airbag systems and a few other things, Are you going to be stripping it? or making it a street trim track car?
Also as far as comfort inside the cabin, the only thing is that the sedan doors are shorter, as is the front seat, but again if you are making it a track car, with an aftermarket seat you should be good.
As far as accessability of parts, when it comes to mechanical, suspension, drivetrain, its all the same pretty much. If not the same as the coupe, it wouldnt be that much harder to find, It only starts to become a pain when getting into body panels, dash's door cars. that kind of stuff.
After that all i can say it... DOOO ITTT
dinanm3atl
12-07-2009, 05:26 PM
The seats are the same minus they don't tilt/flip forward to allow backseat passengers in. Also to my knowledge nothing changed from 97 to 98. Some standard features were added like 3 spoke steering wheel and some minor refinements but nothing in terms of weight is different. They all have the side airbags and driver and passenger airbags.
In terms of weight it is NOT that much. 50ish pounds if I remember. The chassis is slightly stiffer due to the fact that it actually has a B Pillar and not just glass in the middle. Overall the difference is not that great. I would get the one that is cheaper.
Parts? They all fit the same in terms of anything important for a track car minus the roll cage which would be done on a 1 off basis and to your specs. It is easier to get into the car for work in the sedan. I can attest to that. Crawling into the back of my M3 coupe with a half cage was a big pain in the ass.
So hope that helps.
Tony Soprano
12-07-2009, 05:28 PM
sedan ftw. :)
http://i14.photobucket.com/albums/a311/versionJDM/024.jpg
Geoff.T
01-04-2010, 03:49 AM
So hope that helps.
My '97 sedan didn't come with Side airbags.
