View Full Version : Air ride for a Q45
Amoney47
04-15-2011, 02:22 PM
Who makes a kit, so far i have found airrex and airrunner, is there any other options out there
cheez80
04-15-2011, 08:08 PM
UAS over coilovers, bold world, canover, aimgain, and so on and so forth.
Jpclawson
04-16-2011, 05:02 AM
what year q45? if its the G50 (90-96) send a pm to jltibbs on here and he'll hook you up. he was on air a few years ago.
Amoney47
04-17-2011, 11:52 PM
i have a 99
xseveredveganx
04-20-2011, 12:30 AM
If this was the option I was going to run with my Y33 (97-01 Q45), I'd rebuild the struts with shorter Bilstein or Koni inserts and run UAS bags.
You can run your stock struts with UAS bags, but you probably won't get all that low. It all depends on how low you want to get.
Amoney47
04-20-2011, 10:46 PM
i just need struts or a strut bag combo. im going to be running accuair. but i want to be able to lay on the ground or as close as i can get
xseveredveganx
04-20-2011, 10:52 PM
If you're looking for struts that aren't already on your car, a junkyard would be your best bet.
Why not just weld on the UAS brackets onto your current struts? If the struts are blown, you can get new cartridge inserts from Infiniti.
Amoney47
04-20-2011, 11:25 PM
cause that wont go low enough it will bottom out on the strut before it gets to where i want it to sit.
Amoney47
04-21-2011, 10:18 PM
so i decided to do a megan coilover with a uas bag setup
FreshLikeSushi
04-23-2011, 09:18 AM
s13 suspension swap with coils and uas is the best way if you wanna be on frame rails.
not the same body, but same chassis, on the ground, and thats what i did
http://farm3.static.flickr.com/2415/2238850508_68326e2210_b.jpg
AccuMike
04-27-2011, 04:28 PM
DAMN! That thing is nutty. Can't wait to see how yours comes out Austin!
Amoney47
05-03-2011, 08:09 PM
me either counting down the days till my stuff arrives
