View Full Version : The What's Wrong With Your Car Thread
Hinman
10-19-2009, 07:16 PM
So I feel like there are a lot going wrong with my car all at once and it sucks :( I've seen this type of thread on other forums, but not here.
Lets see here:
1.) Rear window regulator broke
2.) Interior trim on the drivers door fell out and cracked (just needs new clips)
3.) My MAF sensor is bad
4.) I have a small coolant leak ( I think i finally found it)
5.) Squeaky brakes
6.) Clutch is about shot
7.) On my headlight assembly, the clip that holds the turn signal in on the passenger side is broken, so sometimes my turn signal falls out and hangs by the cord.
8.) My door panels are starting to come undone.
9.) Blown speakers
10.) Steering wheel leather is fading
11.) Needs repaint BAD
12.) Headliner stained
13.) Broken cigarettes light
14.) Scratched interior molding
15.) Ripped shift boot
16.) Broken shift knob
17.) it has 146,xxx miles.
So, what is wrong with your car?
MrJereMoose
10-19-2009, 07:32 PM
1) Climate control works when it wants to (just pulled it out today to fix)
2) Some sort of tail light failure, or so it seems to think...
Burn535i
10-19-2009, 07:50 PM
1. My headliner is sagging
2. My dashboard has a crack in it
3. My car shakes at 55 mph and I can't pinpoint what's causing it
4. I have an automatic
Relax
10-19-2009, 07:57 PM
1. The driver...
Hinman
10-19-2009, 08:18 PM
my car actually does this as well.
Chase
10-19-2009, 08:30 PM
broken oil filter housing
lifters are ticking, so i need to reinstall my cam
need to repaint my rear bumper as its the wrong color
need front bumper
fender arch trim missing
ive got wires everywhere, need to finish my gauge install
steering wheel is falling apart
need a new motor mount
Stephen
10-19-2009, 08:37 PM
Need to fix the ABS
Some weird lighting bug
Rear shocks dont dampen properly
a scrape on the side
slightly skewed hood
mojocoggo
10-19-2009, 08:50 PM
It didn't qualify for Cash for Clunkers.
Burn535i
10-19-2009, 08:52 PM
It's so damn frustrating because I am trying to sell it too and I don;t have the money to start replacing a bunch of shit to try and fix it
southpaw
10-19-2009, 08:58 PM
1. hit and run = damaged trunk/rear bumper
2. hit many things with the rear bumper
3. cracked/sharpied front bumper
4. so many rock chips on the hood as well as dents from drunk friends
5. sunroof is stuck partially open.
6. it has 2 pedals.
7. the license plate LED lights are always on (left) or never on (right)
8. dent/chip in rear fender when razor scooter fell off roof rack in traffic
9. fuucked up fender paint from rubbing.
10. exhaust hangs too low and is crooked.
11. coooland leak.
12. always a blown shock somewhere.
13. needed maint about 4500 miles ago.
14. subframe is prob fuucked up
15. fender liner is totally fuucked
16. blown speakers (2)
17. love stains on headliner? :shifty
18. even after 4 alignments, it is still out of alignment
vdubkid
10-19-2009, 10:54 PM
1. bought a used set of coilovers
2. installed them myself
3. all four corners rattle
4. all four wheels are out of alignment (after three trips to a shop)
5. need a new shift shaft seal
6. clutch slips
7. dead pedal is broken
8. front bumper looks like the moon there are so many rock chips
9. rust stains all over the paint
10. dead bee in my tail light
11. huge scrapes on the front, rear, and both sides
12. needs new tires
13. cd player skips on just about every cd, new or old
14. but worst of all, it's not low enough
Stephen
10-19-2009, 10:56 PM
i like how you guys e46's have longer lists than my e30 :rofl
oh, well, your cars look good
vdubkid
10-19-2009, 10:57 PM
they're so cheap these days for good reasons haha
SeanDub
10-19-2009, 11:34 PM
Its a BMW
Tuck&Poke
10-19-2009, 11:48 PM
wet sanded door, needs to be polished
left front rub strip is wavy from when the body shop dude pulled it out
soft touch is peeling, getting it recovered in super top secret material
wheels need refinishing
thats all thats wrong with it, the rest is shit i want to do
Byron
10-19-2009, 11:50 PM
Accidentally jumped it today, so probably quite a few things, lol. A transmission mount for sure, probably a motor mount.
radiator support
exhaust (perfect shape just sounds horrible)
As for the m30 car- too many things to list, but #1 being the engine sitting 3 feet in front of the car.
B Rod
10-19-2009, 11:51 PM
E28:
1) Needs valve adjustment
2) Driver seat it torn
3) Shakes at inconsistent speeds but mostly around 80mph
4) Brakes make it shake sometimes
5) 3rd grinds on down shifts if I don't ease it into gear.
E36:
1) Has the wrong engine in it
E30:
1) Is currently running on 5 cylinders
2) Leaks from a small coolant hose going to the throttle body(What is that? I haven't researched it)
3) Driver seat is broken
4) Sunroof crank handle doesn't stay of the roof.
5) Probably many others I haven't discovered.:D
Byron
10-19-2009, 11:53 PM
Throttle body heater
jpod999
10-20-2009, 12:17 AM
-Wierd clunking noise coming from rear half over bumps, only in the rain. I dunno.
-Outer control arm ball joins on both sides are completely ripped.
-Both tie rod ball joints are completely ripped.
-M50 I have for it in my garage isn't swapped in.
-Not on coilovers.
-Lame wheels.
-Paint is in terrible condition.
checkmate2006
10-20-2009, 12:25 AM
1 new front bumper, passenger fog light, and radiator support (killed a kitty cat)
2 need new gauge cluster (speedo and tach)
3 MOAR LOWER
JSanders
10-20-2009, 12:36 AM
Overheated again today 30 miles from my house
Needs new front bumper, the current one is held on by airforce while driving.
Needs BBS
Needs matching door panels
Needs c pillars recovered
Needs new steering wheel
Shake at 60+mph and don't know what else to try replacing to fix it.
Needs new brakes
Richard_Gud.
10-20-2009, 01:47 AM
Uhhhhh.
Front lip is curved downward from scraping it so many times.
Front bumper still doesn't fit right and has a million rock chips/battle scars.
dead mosquito in my headlight [I don't give a fuck, he's staying).
hood has a million rock chips and dent and keyed.
front right volk wheel has major rock damage aka bent lip.
left rear shock is blown.
rear bumper still scratched from being rear ended.
rear hatch keyed from when someone tried to steal my badge.
Interior still in pieces, not finished with it.
325irollin
10-20-2009, 02:18 AM
shit, where to begin.
1. Auto tranny is going bad, electronic shift control light comes on quite often.
2. ABS light comes on, brakes work fine though?
3. Brake pad sensor light stays on, shop didn't hook them up right I guess
4. Brake light circuit fucks up every once in a while.
5. 1 brake light fail
6. Passenger window off track
7. Headliner coming down
thats all I can think of at the moment
E36Bimmer93
10-20-2009, 03:23 AM
I've spent so damn much money on the car in the last year I shouldn't have a list...but I do:
Door panels need to be re-glued
Needs a repaint, and some dents removed
Some rust needs repaired (nothing too bad)
Radiator has a leak, but I bought an aluminum one I need to install
Steering wheel is worn out
Possible blown headgasket, but haven't got into checking that out yet. That gives me a good excuse for an S52 though, so I won't complain
Tranny sticks in 2nd sometimes
Drivers door weatherstripping is shot, but I have a replacemnt on the way
Somethings messed up with my sunroof
I guess that's about it
frink84
10-20-2009, 10:49 AM
needs new subframe bushings
either ds is bad or some bolts are loose on center support bearing
exhaust drones waaaaaay too much (3" all the way back on stock motor = BAD, idiot PO)
rear brakes need redoing (that or BBK)
driver seat has rip
shift boot is torn
cracked windshield
fogs dont work
no windshield wash (removed everything, dunno if i wanna put it all back in)
gumballer_80
10-20-2009, 11:25 AM
*-It's French
*-Both rear tyres are losing air [; no idea why]
*-Freshly painted boot keeps getting small dings after polishing
*-Blown speakers [; 2]
*-Headliner's sagging
*-Dirt stuck in seats
*-Leaking oil [; still trying to pin-point from where]
Zack01GC
10-20-2009, 03:18 PM
-Front and rear windshield leak
-Carpet is faded
-Rear arches are rotting out, as well as front 1/4's
-Odometer broke 5 years ago
-Rear tires are garbage
-Muffler is rotting out around front welds
-Open diff
-Slave cylinder is on it's way out (clutch sticks to floor on occasion)
-Needs to go lower/different wheels
-Paint is terrible (well, it is original)
-Rear rotors and pads are almost shot
-Passenger side rear shock needs replaced
Hinman
10-20-2009, 09:50 PM
Its a BMW
http://i663.photobucket.com/albums/uu360/hinmanmichael/bmw_crazyanim.gif
səˈprēm
10-21-2009, 01:40 AM
e39 540:
check reverse lights (i have hella tails?)
check lic plate lights (they told me i wouldnt get an error)
abs/brake light on dash (abs module)
radio flickers on and off at 30-35mph and 60-80mph
inside door handle pass side broke (keeps the bitches in tho)
fogs need wiring harness for hid and need to be aimed
sunroof came off rails and broke
brake fluid pretty low
timing chain tensioner needs replacement
Russell_G
10-21-2009, 02:03 AM
its not finished yet.
schroedin
11-25-2009, 12:07 AM
New updates :rofl
I fucking steamrolled a dead deer in the road cause I couldn't avoid it, It ripped out my front undertray thing and one of my brake ducts, those disappeared forever. Also, my front drivers lock cylinder is fucked up, so I have to lock/unlock my car either from the passenger door or the trunk. :(
e34
1. Needs antifreeze
2. Needs oil changed - this weekend
3. Needs front bumper fixed
4. Needs fender fixed
5. Needs CCV valve installed - this weekend
6. Needs bigger front tires and smaller rear tires
7. Needs CD player installed - this weekend
8. Needs more bass in the trunk - this weekend
9. Needs to be PDR and high speed buffed - this weekend
10. Needs to be driven like the beast it is.. :D - this weekend
So basically 6 out of 10 will be done this weekend.
Dr.AK
11-25-2009, 12:36 AM
How did I miss this thread? Haha.
front doors need to be replaced because of rust
front right fender needs replacing because it was a low quality replacement after the previous owner banged up the original one
starter needs replaced
there's a hole in the drivers seat
rear hatch dampers need replaced
Reichy
11-25-2009, 12:38 AM
e36
1. Someone smash up the trunk and one tail light with a bat!
2. Needs new Front seats
3. Tiny Coolant leak (which pisses me off cause i paid to get it fixed already)
4. Need to get my coilovers from the police. (long story I'll tell ya later)
5. Needs wider rims to be stanced
ollycarbs
11-25-2009, 06:02 AM
i am so glad to find that i will finally be able to clean out my closet because there is a lot to say.
Passat TDI 1996
-when i bought it no reverse lights and water temp gauge not working. Done
-two months later the engine broke down, a timing belt pulley ran away: 5valves on the 8 were bent etc... after 4 months: Done (i discover a lot of adorable things..)
-i remove the trailer hitch and my bumper fell down, the hitch maintained the bumper in place, the bumper cover is now hold in place with steel string (?) and 6 screws..
-i have to change the two right doors, the front is rusty as fuck and the rear is bent so when it rains outside, it rains inside too! the bottom of it is about 1cms or 2 of filler!
-the right rear fender is like a MX terrain and not the same colour like car...
-windshield bay is rusty allover and so it rains inside the car and on my beautiful headliner and on the fuse box and the wiring harness.
-the wiring harness obviously is partly cut and rewelded with tape by the previous owner so, sometimes there some sparks coming form there...
-all the plugs of the light switch are welded on the wires since it goes from US switch to euro one (and i plan to redo all of that and remove the alarm)
-the carpet is rotten
-seats are unconfortable, and impossible to set due to the rust on the system, i hope one day to have a leather interior
-the exhaust is so low under the car that it scraps really too often
-there is so much scratches that i can't count them!
-the engine dance on its mounts at 2500rpm and constant speed... sometimes ti seems that it will go out of the car!
-it is a TDI and 90hp...
The 1983 E21 bimmer:
-front drive train dead, all has to be replaced
-front windshield defrost dead for 2 weeks (it rains all day those times)
-some rust on the rear end, under the left side window and under the passenger door.
-right front brake disc bent...
the 1981 Passat wagon:
-as someone previously said: it is not finished!
that's all...
e36
-Burning oil, like 1liter pr10000Km
-Rear break hoses need replacement (ive got them, just not gotten around swaping them)
-Gotta replace Rear breaks soon
-Powerstearing pump needs replacement soon
-Oil/filter change is overdue
-A little bit of Rust on all the fenders and around the drivers front door.
-Ow, and my left front fogligth with aftermarket xenon is having some sort of issue. So when i turn on my fogs, it turns on then turns of. And at the same time it knocks out the boardcomputer, So i have to disconnect the computer and reconnect it, to get it working again.
raffi91
11-27-2009, 01:22 AM
Austin Mini Copper
-wiring harness is a mess
-oil filter housing need to be changed
-10x7 minilites are rubbing
-Dash needs to be reconstructed to fit Weber side draft
-interior panels need to be redone
E24 M6
-Cracked exhaust mani i need to pull out and weld
-Tranny/diff fluid needs changing
-Tach not working
-Central locking system is not working
-Passenger side door handle is broken
-Valve adjustment
-engine/tranny mounts
-guibo/center axle bearing
-car needs full buff and detail
Im sure something else will pop up, but its the price I gladly pay to drive a old school BMW :D.
Effin' Euro
11-27-2009, 02:15 AM
mkiv:
koni's don't go low enough
needs paint (rock chips in front, oem orangepeel all over)
i need new wheels
headlights need polishing
e21 (build thread coming soon):
paint is fucked-being fixed soon
seats need to be installed-saturday
need eurobumpers
dash is cracked to hell
screw keeping hazard light switch from going off
h/u where it's supposed to be instead of in the glovebox where i want it
needs headliner and carpet
needs new windshield
wheels are way too small and on balloon tires
wayyy too high in the air
i'm sure there is more....
- Brake Pads are shot. Lots of Squeaky.
- Bit of steering wheel shudder at speed, probably caused by the ruined brakes.
- Paints flaking off my front arches due to my rims smashing into them.
- Carbon front splitter is cracked in half due to a rather large speed bump.
- Dash says I have tail light failure, even though I don't, it's due to the LED Rears.
- I have a tempermental reversing sensor, keeps telling me I'm hitting something even though theres nothing behind me
- My sunroof doesn't close once it's open.
d.tek
11-27-2009, 10:09 AM
everything
/thread
hi its me alec
11-27-2009, 09:18 PM
front strut mounts are SHOT in my e46. they have 130,000+ HARD miles on them.. they were original to the car I bought the coilovers from. clunk city
e30 is unresponsive, waiting for medical staff to arrive
6erWebb
11-28-2009, 02:50 AM
My ENTIRE suspension is entirely too soft.
And my exhaust is the lowest point under me ride... a full 2 1/2" lower than the floor... yeah...
06tiburonofdoom
11-28-2009, 09:44 AM
Tiburon:
-It rubs :)
Civic:
-Rip in driver's seat
-Fading steering wheel
-D15B8 drivetrain SUCKS ASS (but gets 46 mpg, so I can't complain too much)
-Weird outward dent on hood
-Dent in dash where the plastic under the vinyl was broken
-Motor mounts are history
-Trailing arm bushings are goners
slocar
11-28-2009, 11:19 AM
Nothing really aside from the fact that I have too much camber in the rear and that it seems to be munching up my rear tires pretty good.
LuckyBoyOne3
11-28-2009, 05:44 PM
Don't have sway bar endlinks on the front
Drivers door seal
Ugly winter stocks
P0174 p0171 Lean condition codes every effin day
Front splash guards we drug off
chev_chelios
11-28-2009, 10:38 PM
you guys need to cheer up. 25 of my 27 cars (give or take as i lost count) have been the biggest pieces of crap on the planet. i have never owned a new car and at this rate, i never will.
currently - my square needs a master cylinder and a warmer climate & the gti needs someone with a job :(
HOLES
11-29-2009, 04:59 PM
fucked rear bumper
old headlights
coils are sitting waiting to be installed
need new tires
need new floor mats
want to remove tint
dents on rear wheel wells
Rhynolite
11-29-2009, 11:48 PM
Burns pretty quick
Need a new front bumper
Needs control arms
Shakes at 75ish (prob control arms)
Needs tuning
Audio system needs to be reworked
