View Full Version : how much to cut on the e28?
budski
04-06-2011, 12:00 AM
just curious how much coil some of you guys cut? I'm pretty much planning on dumping mine and needed to know whats too low before i start running into serious problems. Thanks
shaggy
04-14-2011, 11:01 AM
u killing urself
ps: dont cut springs, son
MaxBell
04-14-2011, 02:30 PM
+1
BMW are fine vehicles. When you start cutting coils, you'll damage your suspension. You're not driving an 87 Monte Carlo with springs the size of John Deer tractors. You cut out of a little car's spring and you will have a car that sags, bottoms out, corners like trash, but is a little lower.
Go save some money, buy some H&R sport springs and stop being such a hilly billy.
/rant
Mr.Popeki
04-14-2011, 04:58 PM
save money and buy coilovers!
Stephen
04-14-2011, 08:30 PM
'cause no one on here runs an e28 with cut springs..
OG patina
04-14-2011, 09:07 PM
:D
Anonymoose
05-04-2011, 09:33 AM
Just take em out completely and be done with it ;)
B Rod
05-05-2011, 11:09 AM
Half. Not kidding. I drove for almost a year like that with NO problems. Didn't even ride bad or blow my shocks(some how). Bumps are a little rough, but otherwise, go for it.
SeanDub
05-05-2011, 11:12 AM
Lol at not realizing most e28s here are rolling cut springs.
Joshbm
05-05-2011, 11:16 AM
+1
B Rod
05-05-2011, 12:51 PM
+1
Obviously this is the optimal route to take, but spending $1200+ on coils for a $1000 car sometimes isn't the most umm, economical? Lol.
Dudermagee
05-05-2011, 12:53 PM
cut em like an emo
Moose
05-05-2011, 03:53 PM
It's a fucking 1980's five series lol, chop that shit up.
2.5 off each end is a nice start for a "sport" drop, and the car will still ride like factory excluding MASSIVE bumps. You can go further as necessary.
D Unit
05-13-2011, 01:29 PM
How much would you cut if you had SPAX springs?
budski
06-16-2011, 07:20 PM
just an update, I ended up cutting 3 before I noticed how close the pan was to the ground. I still need to get the new 16's mounted and the skid plate on before I cut anymore but I'm sure it will be at least another 1/2 coil.
for fun I threw some 18's on the rear (front wouldn't clear strut)
http://farm6.static.flickr.com/5080/5840503063_a1401f3d80.jpg
D Unit
11-09-2011, 11:28 AM
I already have lowering springs but they're not low enough with Bilstein shocks. How much should I cut? Do you guys cut the springs while they are still on the car or should I remove them first?
http://i43.photobucket.com/albums/e386/EazyM3/IMG_2844.jpg
DDM
11-09-2011, 01:49 PM
The springs are probably under pressure, so if I were you I would remove them first...
Please do start saving for coilovers though, it's worth it;)
B Rod
11-09-2011, 04:08 PM
If the car is raised up and the spring isn't compressed at all, go ahead and cut with them on the car. Otherwise definitely take them off to avoid injury.
FunfGang
11-09-2011, 04:09 PM
Runningpanda is running 3 coils up front and 2 in the back...(not cut, total) on all stock suspension. Get that bitch on the ground.
Dangerwillrbnsn
11-29-2011, 11:31 PM
I cut 5 in the rear, 3.5 in the front. Don't know if non-sport suspensions will be different... IS's got a Bilstien setup.
Car on 16's
http://i968.photobucket.com/albums/ae166/dangerwillrobinson/IMG_20111004_064845.jpg
Car on 18's
http://i968.photobucket.com/albums/ae166/dangerwillrobinson/IMG_20111029_064941-1.jpg
jamesfawcett
12-01-2011, 04:20 AM
Hi Budski,
from experience, cutting two coils from the rear standard springs of my E28, and one and a half coils from the front, the car sat perfect and it actually stiffened up the ride. I was very happy with it... for a few weeks.
then i tried to go mega low, and cut more coils, and ended up with a horrible bouncy ride.
so from my experience, dont go over one and a half from the front, and two from the rear unless you want to ruin the ride.
MTBIMMER
01-16-2012, 01:21 PM
did you cut your bump stops at all when you cut 2 from the back and 1.5 from the front?
