View Full Version : E36 rear camber, want more! need help!
pumpin_fistsE36
02-04-2011, 06:47 PM
im curious as to how i can get most negative camber out of my E36 coupe.
all of the camber arms that i have looked at all only give around -1 degree...lammmme! tires will last way too long :eyebrows
i want to run around -3 or -4 to fit my wheels
if anyone can help me accomplish this please help me!
Byron
02-04-2011, 08:17 PM
Lower your car. If you're at the correct height to make camber look good, you probably already have 3-4 degrees. And most camber arms will give you more than 1 degree, and don't forget that the extra will be added to what you already have.
pumpin_fistsE36
02-04-2011, 08:57 PM
my rear is maxed out right now but ill take the collars out soon, you are a smart man though i didn't even think that it'll add to what i already have, thank you!!
Bruno730
02-05-2011, 11:47 AM
what type of adjustable rear control arms are E36 guys running?
SeanDub
02-05-2011, 12:48 PM
I run TMS
Bruno730
02-05-2011, 02:52 PM
I'm assuming you're happy with them? what bushing style did you go with?
SeanDub
02-05-2011, 04:51 PM
Love em, I got rod end
Bruno730
02-05-2011, 06:20 PM
thanks for the info sean.
SeanDub
02-05-2011, 09:26 PM
No problem, I've also heard good things about GC so you may want to compare them price wise
Bruno730
02-06-2011, 11:57 AM
Yeah i was happy with my G/C coils but i got the zero clerance coils so I'm going to try to do all susp. components at once.
pumpin_fistsE36
02-06-2011, 10:41 PM
im gonna go with the BAV auto ones and see how they work out
ninety4e36
02-08-2011, 08:16 PM
im running -3.5* in the rears. but its slammed and 15mm spacers in the back
pumpin_fistsE36
02-08-2011, 08:20 PM
thats what im gonna do except with a 10'' wide wheel and 10mm spacers so i need to crank the camber in
ninety4e36
02-08-2011, 08:29 PM
yeah im running 18x8.5 et15
no adjustable rear control arms
pumpin_fistsE36
02-08-2011, 08:36 PM
oh okay, i might see what happens before i get them rear arms, maybe itll work out
ninety4e36
02-08-2011, 08:44 PM
yeah and if anything just roll/pull the fenders.
pumpin_fistsE36
02-09-2011, 09:03 AM
well i already cut my fenders so they are paper thin, i really dont want to pull them lol
dfreshx00
05-08-2011, 01:40 PM
get a friend who works somewhere where you can get to an alignment rack. the stock rear control arms, with coilovers, can get to near 3.5-4*. ask me how i know.
pumpin_fistsE36
05-09-2011, 12:57 PM
i figured out how to get more camber :) i have camber arms but havent put them in yet but i figured out the centric bolt gives more neg camber
MrFukengruven
05-10-2011, 11:11 PM
FTW! I have no adj. rear control arms either. I run 17" x 9.0" Kinesis K57's in the back with an ET26 in the back. Camber was measured on a few occasions. My stock RCA's have held up to more than -3.5 in the back with daily driving and track events :D
da_joint
05-11-2011, 06:49 AM
got any pic's?i'm curious how the they look with -3,5 camber
RIcKO
05-12-2011, 02:04 PM
how much costs the camber arms ?
pumpin_fistsE36
05-16-2011, 07:32 PM
they typically run from $150 to $250 depending on the brand, install is a nightmare though...
pumpin_fistsE36
05-16-2011, 07:35 PM
im running 17x10 et0 BBS style 5's right now with slight fender pull/shave with stock control arms and -4deg camber
Aphrodizeac
08-02-2011, 01:44 PM
Interesting.. I'm on 17x8.5 ET13's with no adjustable control arms either, no spacers, and I have about -3 degrees all around.
