View Full Version : 17 x 9.5 final offset 10 does it fit e36 ?
Sam_bmw
01-08-2011, 10:54 PM
so yeah im looking for 17 x 8,5 et 30 17x 9,5 et30 and for the rear i want to know if it would fit with final offset 10 and a nice tire stretch ?
i would need a camber rear kit ? thanks alot:D
Ollie
01-08-2011, 11:58 PM
Yup. You'd need a decent amount of camber and stretch but it'd work. I'd personally go with an et15-20 but depends what you're going for.
cabezzz
01-09-2011, 01:29 AM
As mentioned above camber and stretch, as for tire a 215 40 should work
here you go. (http://forums.bimmerforums.com/forum/showthread.php?t=1528718) you can find more post of his setup, by searching his name. those are 9.5et13
in this thread (http://forums.bimmerforums.com/forum/showthread.php?t=1448991) is a good picture of his rear wheel, about half way down on his post.
I have 17x 8.5 and 9.5, but my Et's are different. They're 13 and 21.
Sam_bmw
01-09-2011, 11:39 AM
i got no choice to take a 20mm adapter to make it to et10 since that there is no smaller adapter .
so i would need a 215 /40/17 and camber rear arm ? do 205/40/17 would be too much stretch on a 9.5 ? thanks !
Eurotrashedlife
01-09-2011, 06:09 PM
205 on a 9.5 is a pretty hard stretch but hey, guys stretch 185s on 8.5 wides on dubs so it's do-able. 215 would definitely be a better fit though. Throw a 205 on the front and the 215 on the rear. Also, there are places to source 10mm adapters out there if you want to go with a +20 offset.
Sam_bmw
01-09-2011, 06:13 PM
yeahh i might go with 215 :) , for the offset i got no choice to go with offset 10 since that the wheels are 5 x112 i need adapter and the smallest adapter i can get is 20mm i think
Depending on what your gonna end up with suspension wise, 215 front 225 rear is what I was going to suggest. Do you have a pic of it being dry fitted? A teaser maybe???
Sam_bmw
01-09-2011, 06:50 PM
nop not for the moment i need to ordered them :) but if it fit with no major works i will get them and put 215 40 rear and maybe 205 40 front since that the front is 8,5 ..
for now im in coilover ... and later on bags .
but i dont want to much poke in the rear .. my last setup was 8,5 et13 in the rear so maybe 9,5 et10 with camber ajustement the rear would fit perfect :)
Francois Dillinger
01-09-2011, 07:04 PM
You can have 15mm adapters made. And 205 front, 215 rear.
Sam_bmw
01-09-2011, 07:33 PM
link that made 15mm adapter ? i didnt found on adapitusa...
Sam_bmw
01-19-2011, 05:18 PM
UPDATE :D , i ordered the wheels 17 x 8,5 et30 front and 17 x 9,5 et 30 back , im ordering some 20mm adapter all around with 2 tires 205/40/17 and 2 tires 215/40/17 , so i will have a final offset of 10 all around , now what do i need to make them fit proper fitting ?
i might ordering a camber rear arm kit what is the best for the buck ?
thanks everybody !
rear camber, they are all around the same price. tuner, GC and eibach(spelled?)
what wheels did you get btw?
Sam_bmw
01-20-2011, 01:50 PM
Amg 3 piece :)
btw what is the best camber rear kit that i can have alot of negative camber ?
FABEL
01-20-2011, 01:59 PM
got pics?
Sam_bmw
01-20-2011, 02:17 PM
http://img560.imageshack.us/img560/8743/a4003.jpg
same as those amg:D
i will take picture on tuesday when i receive the wheels !
Sam_bmw
01-22-2011, 07:47 PM
i just ordered a camber rear kit UUC and i would like to know if -3 of camber will be good ? thanks
Sam_bmw
02-01-2011, 05:40 PM
might do a test fit soon :)
