View Full Version : 1990 Honda Civic ED4 sedan coilover question
iheartmyed4
01-08-2011, 11:40 AM
Hey stopped to ask a quick question and where best to ask a suspension question then the lowest whips around forum right? Anyways, i have a Honda Civic sedan 1990 ex and would like to remove the adjuster plate so it will sit lower in the rear and maybe the front as well, there just a ebay coilover and i have stock struts, yea i know but i wanna sit lower, any thoughts or opinions on this?
Ed6_Civ
01-08-2011, 11:58 AM
when i started shopping around for coilovers i was going to go function and form type 2 coilovers for my hatch. theyre fully threaded, and relatively cheap compared to alot of others. i ended up finding something else for what i want so i didnt get them.
they would have been my choice if i didnt go the route i took.
iheartmyed4
01-08-2011, 01:29 PM
What about just removing the coil packs and leaving the spring only?
Ed6_Civ
01-08-2011, 03:20 PM
the ebay coil sleeves wont get you low. there a coil over sleeve system. leaving the "spring only" will only get you maybe 1/2 inch at most.
if you want low theres 3 ways people go about achieving it, coilovers, air ride, and cut springs. pick what suits you best. having cut springs isnt the route to take, but on a very low budget will get you by.
id go coilovers on a ef sedan, but i guess that just my opinion.
trism
01-08-2011, 09:42 PM
Also dont forget extended top hats
allows you to drop the car that amount, without losing shock travel, like you do with coilover sleeves.
http://img412.imageshack.us/img412/640/gcmountsif7.jpg
you can get ground control ones, that are only an inch and a half or so.
or custom make your own, and go all the way up to 3 inches.
ogphotos1993
10-30-2012, 03:08 AM
^^^ What he said. You might wanna change your shocks. I have a ef sedan myself. except mines a 91 ex.
Get tokico blues, Ground control coilovers, Extended top hats. You can have some made or better yet, Buy them. Good luck on the build! Here's a pic of my buddies old sedan with the same set up I told you just now.
http://farm8.staticflickr.com/7076/7371013218_8ac248807a_o.jpg
EF303
04-19-2013, 12:36 AM
Does he have a build thread or something? Every suspension thread about Tokicos/GCs has some guy saying he's "bottomed out" on his sleeves and he's barely tucking tire. Since I've currently pieced together a whole setup of Tokico HPs, off-the-shelf Ground Controls and extended top hats for my ED7 hatch, I really really REALLY wanna know how he got that insanely low on that setup. Shorter springs? Custom rates? No sleeves? I'm dyin' here :devillook
