View Full Version : Question for those running full struts...
I have a vast background in air suspension doing chassis fabrication and setting up suspensions using Slam bags and the like, Slam bags > all, But here in aus 'struts' for cars are usually built by one guy down here who has an ADR approved product, that would pass an engineers test. These are around $5000.... effe that.
Now I read a fair bit about guys in the US running aftermarket shocks and bags, I take it these would screw on similar to a coil spring set up?
I am looking to bag my legend in the future, and need to find out what would be the Ideal setup for a larger vehicle that has an extremely limited aftermarket base.
I thought about trying to get a kit along the lines of a GS300/Aristo being a similar size car, and modifying mounts to suit, but would much rather throw something together to achieve optimum ride quality.
Any help appreciated, fitting/modifying components to fit is no dramas, just dont know what brands are superior in that whole field.
Do you mean like an Universal Air Aerosport over shocks/struts? If so, everyone and their moms run those here.
Pretty much... I need awesome shocks and awesome bags to put together to run on my 1992-1995 KA7 Honda Legend.
Make sure the Aerosports have clearance on that car and if they do, get yourself a set of either Koni or Bilstein shocks or if you want to get more adjustablity/fine tuning, get some coilovers and use the Aerosports over those.
https://www.universalairsuspension.com/store/product_info.php?cPath=25&products_id=29&osCsid=9575aae8d147eb1c4395f56ad9a60862
Bags over coilovers example:
http://farm3.static.flickr.com/2197/2079600061_39f2b34855.jpg
There isnt a great deal in the way of coilovers for the KA7's, I think D2 or one of those companies make a set, which are quite aids, and then theres one or two companies in Japan, but they're like $4k
Thanks for teh info Han, interesting.... * Strokes wizards beard *
martinm13
01-01-2011, 10:12 PM
http://www.imageinmotion.com/KSPORT05-CAC08-RR.htm
dont know if these guys ship to australia though...
blkvip
01-02-2011, 01:44 PM
for strut/bag could easily go usa bags with a good strut that fit ur car.koni kyb ex.. coil/bag: d2 isnt bad for daily usage if herd, performance wise not so muchbut least with d2 your getting dampner,compression and rebound adjustment
trism
01-02-2011, 08:07 PM
Also considered doing this.
Need to modify the upper and lower spring perches for things like airlines etc though right?
I guess to begin with I could use a basic shock set up, then upgrade down the track to something with adjustable rates..
Judging by the UAS bags, only the lower mount needs to have a spot for the air fitting... You cant use stock spring perches as such though, need to mount perches that the bags can bolt up to..
martinm13
01-03-2011, 08:15 PM
i have the uas bags and they just have a steel plate bolted to either side of them for support and they are resting on the stock perches. i just had to cut a hole for the fitting
From an engineering view point, the mounts that bolt to the bag should be fixed/welded to the strut housing.
Pasquale
01-08-2011, 02:40 AM
Sorry for the shit picture but here are my ksports with UA AeroSports...
http://i42.photobucket.com/albums/e308/pasquale123/76635_175788229103186_100000160308343_652839_66064 01_n-1.jpg
Jesse@AirLift
01-19-2011, 05:07 PM
Hey Oxer,
If you are down to fab a complete strut, I have 7 different set-ups with different valved struts. They are universal, as in build it yourself. I have ran them on just about everything there isn't a kit available. The downfall of sticking bags on any strut not designed for air is seal failure. Most aftermarket and factory strut bodies can't handle the internal pressures of the airbag. Hit me up if you have any questions and I will gladly point you in the right direction.
jjenson@airliftcompany.com
