View Full Version : Options to get lower?
socalE320
12-25-2010, 12:03 AM
Hey guys I have a 98 E36 M3 on Tien coilovers now the rear will go low enough but sadly the front will not :( and I refuse to have reverse rake is there anyway I can drop the front lower? its already cranked all the way down is cutting the spring from the top an option? or any other ideas?
Thanks guys im sure well come up with something ;)
Kielan
12-25-2010, 12:09 AM
Zero Clearance Coilovers will solve that problem. :)
socalE320
12-25-2010, 12:11 AM
I know.. I seriously wish I had the funds for those :( but in the mean time was thinking of either cutting the springs in the front not too much maybe 1/4 - 1/2 coil as im sure that will lower it much more than cutting lowering springs did. Was also wondering if I could take it somewhere and have more threads added? therefore allowing me to crank it down more?
socalE320
12-25-2010, 01:01 AM
Also would it be safe to remove one of the locking collars from the front? Or does that seem pretty dangerous? just trying to throw out ideas haha
kartikeya
12-25-2010, 01:39 AM
You'll have to forgive my ignorance on E36 suspension and the TEIN units you're using, but you should be able to use the bottom bracket and spring perch/collar to lock against eachother, thusly eliminating 2 collars from the equation.
socalE320
12-26-2010, 11:17 AM
hmm not sure what you mean but ill jack up the car and try to see in a few minutes.
Is it safe to run with just one of the locking collars and eliminate the bottom ones? or would that be a bit risky :o
did you cut the bump stop in half?
socalE320
12-26-2010, 11:42 AM
No I have not figured its not bottoming out on it so it wouldnt make a difference?
kartikeya
12-26-2010, 12:05 PM
Are your coilovers like this, with 3 collars and fully threaded?
http://img121.imageshack.us/img121/1483/teinsdrift.jpg
Or like this, with just two collars to hold the spring up?
http://img207.imageshack.us/img207/8027/teinsuperstreet.jpg
socalE320
12-26-2010, 12:38 PM
let me go take a quick picture but i believe the second one
socalE320
12-30-2010, 12:24 PM
yes confirmed it is the second one :/ is it possible to cut the spring? or would that cause it to not seat properly
kartikeya
12-30-2010, 12:54 PM
No. Just, no.
The most cost effective solution that doesn't involve cutting springs or using shorter ones that will kill your suspension travel, is to sell these coils and get proper new ones.
socalE320
12-30-2010, 02:01 PM
Any recomendations to some budget friendly coilovers?
AccuMike
12-30-2010, 02:08 PM
air??? :)
socalE320
12-30-2010, 03:10 PM
air??? :)
Eh not really feeling air for the M3 thats more of something I would have done to the 210
Jamxx
01-01-2011, 01:51 PM
There is absolutely no issue with removing the bottom locking collar as long as they are spun all the way down. Otherwise you're going to have to do something with mounts and whatnot, nothing left to do on the coilover itself.
SceneBM
01-01-2011, 02:58 PM
do your coilovers have helper springs? in my old Polo i removed these plus the bump stops and it gave me over 30mm more drop
jersey bimmer
01-18-2011, 01:14 AM
having the same issue with my ground controls.... is cutting a coil a terrible idea? granted i dont care about the one or so less inch of suspension travel that i will be losing.
Glissoar
01-19-2011, 09:48 AM
I have heard of people cutting out a section of the strut on your front coils and welding it back to get lower in the front, don't know if someone suggested it already
