View Full Version : lowering a truck
OhYamp
12-22-2010, 04:11 PM
i have lowering springs in the front and 4inch drop blocks in the back,, anyone know how i can go lower without bags?
kartikeya
12-22-2010, 04:34 PM
Some popular models have drop spindles available.
Some information about your truck would be useful for those trying to help.
OhYamp
12-22-2010, 04:37 PM
i have a 93 mitsubishi mighty max,, n thanks man
Craig
01-05-2011, 09:22 AM
pull one or two leaves out of your leaf pack to get the rear lower.
JSanders
01-05-2011, 09:26 AM
Drop spindles in the front, bigger blocks and removing leaf springs in the rear.
With out a notch, you will be limited to when the diff hits the chassis... I thought these were torsion bar front end?
The other option in the rear is as said, pull leaves out, which will make the ride very soft and floaty, or flip one of the smaller leaves over on the leaf 'pack' to make the leaf 'pack' straighter, therefore lowering the rear.
Regardless, the ride wont be comfortable.
You will also need shorter shocks.
Craig
01-05-2011, 09:34 AM
could you go more into detail about 'flipping' one of the leaves to straighten out the leaf spring i've never thought of that and sounds like it would work.
thehillshavestis
01-06-2011, 08:44 PM
im not to familiar with the rears in one of these but is the axel on top or on the bottom of the leafs. if its under, then flip it. put the axel on top. you might need to notch the frame to accomodate the axel tho. not hard i did it to a friends chevy.
is it 4wd? the front might be hard if it is
UnitedWeStance...
01-07-2011, 01:22 PM
The front end should be a torsion bar set up. If it is, you just need to adjust the torsion bar bolts to drop the front. As far as the back, I think it is as low as it will go before you will hit the frame. If you wanna notch the frame, you can use lowering shackels to get about another 2 inch drop out of it. Taking leafs out of the springs is also a way to do it, but I wouldn't recommend it. Hope this helps.
If I can find some old pics of some of my previous set ups Ill post them...
Bracknaphobia
02-09-2011, 07:28 AM
Step One: Work
Step Two: Save money
Step Three: Buy Bags
Step Four: ?????
Step 5: Profit
kaidotech
01-04-2012, 07:50 PM
Wow, necroing the hell out of a dead thread here but did you find any help lowering your truck? I used to be in a truck club and ate,slept, and lived lowering trucks for a few years.
http://img843.imageshack.us/img843/7145/29172012956670714389910.jpg
HMU if you have any questions about getting low without bags.
Carolina
01-04-2012, 10:59 PM
you dont just turn the torsions you will grind them of in like a day and you still wont be as low as you want you may have to re-index your torsions which just means taking them out of the bracket and turning them one two or three splines depending on how low you want to go. as far as the back i have my overload leaf on top of the main leaf with three inch blocks if you want advice on lowering your truck join the proper forum you will find a ton of great info. But that is if you have torsions..
http://www.mazdabscene.com/forums/suspension/how-index-torsion-bars-with-pics-t22874.html
sorry if i wasnt any help
