View Full Version : how many times to empty out tank?
billy370gt
12-18-2010, 02:32 AM
hey,
new to the air suspension scene :cool, my installer told me that i should at least empty out the air tank once a day? sounds right? and what other things do i need to do to maintain it?
Rally
12-18-2010, 07:44 AM
Once a day? That seems a little extreme.
Where do you live? What kind of weather do you get? Do you have a water trap installed? Is your tank aluminum or steel?
NegativeCamber
12-18-2010, 04:12 PM
like andrew mentioned, a water trap should be sufficient enough for a long time. if you are that worried about condensation buildup inside, id just tap the bottom of the tank and install a ball valve. then, you can manually drain it after a long period of time.
aar0n.
12-18-2010, 04:46 PM
I empty my watertrap when I remember to so it happens about once a month lol. My setup doesn't collect much water in the dryer so it's nice. I've emptied the tank a handful of times in the year and a half I've had it and the tank was bone dry each time it was emptied :D
billy370gt
12-19-2010, 06:28 AM
where can i get the water trap ?
DerekKoch
12-19-2010, 10:56 AM
http://www.bagriders.com/modlab/products.php?product=NUMATICS-WATER-TRAP
NegativeCamber
12-19-2010, 03:47 PM
you can get one at home depot for a lot less.
Nighttrain1974
12-19-2010, 04:44 PM
Had a trap in since i had my system installed. The weather is a lot more humid in the uk all year round so it's essential.
Also i've replaced one pressure switch due to water rusting the end of it .
LuckyBoyOne3
12-20-2010, 01:21 PM
I drain my tank once every couple months... and maybe have a half cup of water come out, and thats with no trap, once a day is waaaayyyyy overkill...
Doc
12-21-2010, 08:58 AM
maybe once every few months
usually i do it while showing someone where i have my hidden trap so it gets done then ...
blkvip
12-28-2010, 10:59 PM
just did mine today, I drop of water came out thats it and last time I drained it was aug/sept...
grundle
12-29-2010, 01:31 PM
during the winter when it gets below freezing at night i would def suggest emptying alot more frequently i check mine every other day just to be on the safe side...during the summer once a week if that
Dangler
01-04-2011, 04:06 PM
when i had air ride, i emptied my tanks once after over a year of use. 1oz of water came out. everything else was bone dry. everyones setup is different, so everyone is going to find different amounts.
