View Full Version : 1jz or 7mgte cressida swap
1988montecarloss
12-15-2010, 02:29 PM
about how much would it cost to swap a 1jz or 7mgte and an r154 5spd trans into a 1991 cressida?
and what work would need to be done? ive never really looked into this swap before but im really interested in it because there is a 1991 cressida for sale locally
could the stock 7mge be turbo'd? or do they have weaker bottom ends than the turbo version?
thanks for any help guys! :alright
Jedidiah
12-15-2010, 02:32 PM
moved the thread to Engine and Drivetrain forum. I would go with a 1j, but that's just me.
Average_Jerk
12-15-2010, 02:35 PM
the 7M motors need to have the head gaskets replaced all the time unless they have already been upgraded to a metal one. imo, 1jz is better. both swaps are very common though
Lt. Dangle
There HAS to be something on the internet about this.
I would also go with the 1jz.
I hear that the 7mgte is a way less involved swap, but yeah... I wouls still go with a 1j.
7m's suck shit in my opinion
Kielan
12-15-2010, 02:36 PM
1jz.
1988montecarloss
12-15-2010, 02:44 PM
ive heard about the HG issues with the 7m's but it wouldnt be a big deal to replace the headgasket before the motor was in the car and use some arp studs for extra insurance.
i guess it all comes down to which swap i could do the cheapest, because both motors have tons of potential
1985zcar
12-15-2010, 03:08 PM
Better headgasket, stock turbo set up on the 7M is your cheapest route to go. It can make a decent amount of horsepower. My friend did it on his for a while.
1J is the way better option though. They're bulletproof, super smooth, make good power, sound amazing...and I miss mine :( lol
1985zcar
12-15-2010, 03:10 PM
And as far as the swap goes, it's pretty straight forward. You'll need to order jdm/aftermarket engine brackets/mounts, there's some wiring involved, but overall, it's pretty easy. And make sure you get a front sump 1J.
kramerbuccs24
12-15-2010, 03:42 PM
Definitely go 1JZ. A few years down the road you can splurge on a 3.0 block or a full 2JZ, lots more modding options with the 2JZ.
jungledorifuto
12-15-2010, 05:46 PM
toyotacressida.net or something
1988montecarloss
12-15-2010, 06:44 PM
the wiring is what scvares me the most. any idea what wiring needs to be done?
1985zcar
12-15-2010, 08:50 PM
Not of the top of my head. My roommates done like 3-4 1J/2J -> Cressida swaps. Check out JZXproject.
Stringbean
01-11-2011, 03:49 AM
my friend had a cressida with a 1JZ, he was gonna TT it, but it blew up.....it was old, he said the !JZ is totally worth it, him and i both loved the car, i had the competitions 89 mazda 929. very similar we both miss our old cars! i crashed mine :( . do the 1jz you wont regret it.
padraigmk3
01-11-2011, 08:43 AM
The 7MGTE will make 300 hp/tq at 18lbs boost reliably all day. As far as BHG goes, toyota's head bolt torque specs were wrong from the factory, and refused to acknowledge this. That's why the 7M has such a bad rap. Get a good aftermarket HG, arp bolts and then re-torque the bolts to 75 foot-lbs.
With that being said, the 1J would probably be more fun. I can't argue with more power. Who can? :)
Are you committed to going NA or turbo?
2jzcress
01-11-2011, 10:01 PM
7m's are fukin junk jz all the way. by the car, save some money , gather parts,join jzxproject ck out my build thread on jzxproject under fuckin showoffs "project fresshida" ps i paid 200$ for my car on craigslist with a blown head gasket:alright
1988montecarloss
01-12-2011, 02:58 AM
i knew about the 7m head bolt thing, and if i go 1jz/2jz it will be turbo
speaking of N/A, do you know of anybody that makes a swap kit (or at least mounts) for a GM LS motor or any other american v8? :alright
1988montecarloss
01-12-2011, 03:06 AM
ive seen your car before haha
thats actually the car that made me want to do this tbh
SedanFromJapan
01-13-2011, 11:45 PM
I'm looking to do 7MGTE, if you get a metal headgasket and torque it 15-20lbs over spec it should be safe, but I wouldn't go over 75lbs IMO, also it's a simple swap 2-3 wire difference, and you can use MX83 x-member and just weld in 10mm ID washers to the x-member cause x83 is 12mm through bolts. I live in AZ and 7M's are dime a dozen here, same with the CT26's, as far as longer lasting, if you're looking to do serious track events with your car, might as well opt out the spare cash for 1JZ, just make sure you get the correct motor the oil pans are different, make sure it's a motor out of a chaser.
Good luck with your swap, hope it goes well whatever route you choose to do.
edit: you have a x83 ignore my x73 rabbling
Oxer
01-14-2011, 07:35 AM
1j > *
padraigmk3
01-14-2011, 12:01 PM
I wouldn't go over 75 either, especially on the stock bolts. You need to get ARP's and an HKS headgasket if you're going to push real power and not worry about it.
As far as "7m's are fukin junk " being some people's outlook, I think that's about as intelligent and informed as saying that 1J's are junk, or 2J's are junk.
It's just a matter of the correct power plant for the application that offers an acceptable compromise between budget, power, durability and ease of install.
SedanFromJapan
01-14-2011, 07:25 PM
Very true forgot to mention ARP head studs, a lil mandatory if you want to make 350wHp and not buy headgaskets by the wholesale lolol, any motor is good if you build it right and take your time to read about them and learn their capabilities, my teamate is running a RB20 with all OEM goodies and metal headgasket no problem, anyways back on topic! 7MGTE is a great alternate to the 1JZ, both are capable of good power, and let's kick the logistics here people, Toyota's are tanks :stickoutt
+1 for someone not bad mouthing budget builds, not all of us can opt out cash for JZ motors.
btw not to thread jack anyone deal with the 1GGTE? kinda wanna go for he authentic GX71 expierence!
1988montecarloss
01-20-2011, 03:34 PM
can you turbo the stock 7mge and make decent power? say 300-350rwhp? or are the bottom ends in the non-turbo versions weaker?
padraigmk3
01-21-2011, 09:07 AM
1) yes
2) no. cam profile and piston shape are the most important differences.
3) http://www.supraforums.com/forum/archive/index.php/t-97101.html
http://www.celicasupra.com/forums/showthread.php?31365-Tire-Shredder-s-7MGE-budget-NA-screamer-build-thread
BLKonBLK98
01-22-2011, 07:12 PM
1uz?
whit3b0y
01-23-2011, 12:19 AM
dude on club lexus is doin 1uz in his... might get in touch with him...
shits sick. i digg. (will remove upon owners request)
http://www.clublexus.com/forums/ls400/340996-post-up-recent-pixs-of-ur-car-171.html
AS QUOTED FROM CLUB LEXUS
Received an email from this forum to post up a recent pic of my LS. Nothing has changed ( I may have posted this in the past).
http://i221.photobucket.com/albums/dd41/yotarip/P1010333.jpg
All stock except the Tanabe springs andEXE Crowns. Still running strong and I love the 1uz. I really what to run it hard but I wouldn't dare beat up on my LS.
Sooooooo.... My Cressida blew it's head gasket a week before X-mas.
http://i221.photobucket.com/albums/dd41/yotarip/P1010196.jpg
On New Years Eve, I decided to build it the way Toyota should have....
http://i221.photobucket.com/albums/dd41/yotarip/IMG_0144.jpg
Cant wait for some full throttle action with the 1UZ
END QUOTE
1988montecarloss
02-26-2011, 06:43 PM
a 1uz swap would be very badass haha
myrmidon
03-17-2011, 11:11 AM
I had seriously considered a 7MGTE cressida swap, it's a bolt-in affair considering that they come with 7MGE's.
Also if you do the 7M swap, immediately swap the head gasket for the thickest one you can afford. These motors can boost just as well as any JZ motor, and they do pretty good considering the price!
Another thing worth considering if a VG30 swap into a Cressida, it's a pretty large engine bay and you would get more displacement at around the same cost as doing a 7MGTE swap, just a lot of custom fabrication. (I would do a VG30E+T to keep costs at a minimum)
stein92
03-18-2011, 04:23 PM
as a toyota tech 7m's can make a tremendous amount of power as long as you can hold it together the shop im at we built one with more than 1000 hp but if your going tranny go for the 6 speed 2jz tranny they are way stronger than the five speed and every 5 speed ive owned blew up after 400 ft lbs of torque but any way you go you can get a tremendous amount of power you just have to find the right parts
oh the 1uz is a great motor but one thing is there is little to know aftermarket for it when it comes to big power thats why a lot swap for something else
K_shan
03-18-2011, 05:48 PM
first of all. the 7m-ge actually came in the cressida's. so swaping to a r-154 7m-gte would be the easier of the 2 since the mounts and such are available through www.driftmotion.com
second of all. the 7m has more displacement and can be more stout than a 1jz.
the thing you need to decide is
do you want to have twins? or single? do you want to rev higher? do you want more displacement?
do you want to perform more wiring work? how much money do you have? do you want coil on plug or coil pack ignition. how much torque do you want vs hp.
anwser those questions^^ and ill give you more info. i am very familiar with both motors since i have owned and worked on both.
7m is the cheaper easier route. and yes from the factory the 7m had bad machining on the head so you will need resurface and get a new head gasket.
hope fully my post helps more than some of these other ignorant posts.
Masonbarnard
07-29-2011, 02:40 AM
1jz and you wont regret it
