View Full Version : Shortened struts
Francois Dillinger
11-04-2010, 10:10 PM
Let's discuss the process :)
82boxima
11-04-2010, 10:38 PM
z31 300zx spindle / strut tubes FTMFL. I'm saving up for some serial9 adapters and tube fab ATM. there's always cheap-o sleeves though :shrug:
Average_Jerk
11-04-2010, 10:59 PM
i bought G60 struts for my E30. im not cool enough to shorten them myself
Francois Dillinger
11-05-2010, 03:33 PM
Hmmm.....
jungledorifuto
11-05-2010, 09:22 PM
remove housing assembly from vehicle, remove insert, find compatible desired shorter length insert with correct valving for desired spring, cut stock perch off stock housing/tube, smooth, measure, measure, cut appropriate length from stock tube, install new insert and washers if needed, re weld, slide coil-over threaded sleeve on, weld, installation is reverse of removal from here out- giggidy giggidy
