View Full Version : Very Bouncy Ride
Red Sled
09-29-2010, 03:31 PM
Just installed a ebay sleeve with qa1 spring 350lb 7in on some kyb agx struts in the front of my b15 sentra...and the ride is very bouncy. The coils arent as low as they can. I was wondering if a 8in spring 250lb would get rid of the bounce..or do i need a stiffer spring..
When im driving on the highway its a constant bounce..or if i go over speed bump it bounces 2-3 times before it settles back to normal..other than that the ride is pretty decent.
firelizard
09-29-2010, 05:35 PM
You need a softer spring, or firmer dampers.
Red Sled
09-29-2010, 05:39 PM
okay so you think the 8in 250lb spring would be fine? or should i stick with the 7in. I called ksport and asked what size spring was ran on my car and they 8in and the rates for the in the front are 336lb.. I figured the softer the spring the more bounce would occur
ak-47
09-30-2010, 05:38 AM
IMO, your struts might be out or need firmer damping as it bounces 2-3 times..
projektzwo
09-30-2010, 08:18 AM
you gitta pick proper shocks my friend...
Red Sled
09-30-2010, 08:56 AM
yea thats what i have heard..i thought it was weird because i know guys that have ran this setup and havent had this problem..and the shocks are brand new..oh well i have something else in mind
hek1620
09-30-2010, 11:10 AM
its the shocks
Red Sled
09-30-2010, 09:01 PM
what about them? just cant handle being that low?
projektzwo
10-01-2010, 01:27 AM
you gotta pick shortened shocks, the bouncing is when the springs are much shorter that the shocks. So now actually you're driving only on shocks, the springs don't play at all...
I know my English sucks, but really hope to understand me.
Red Sled
10-01-2010, 07:42 AM
lol gotcha man.. you english is just fine for me
firelizard
10-01-2010, 08:58 AM
If the springs are too stiff for the dampers, no amount of travel will stop the bouncing.
Red Sled
10-01-2010, 10:15 AM
so your saying a softer spring will help? same length or longer? shorter?
Spoon
10-01-2010, 11:00 AM
Buy stiffer shocks.
firelizard
10-01-2010, 11:22 AM
:alright
Red Sled
10-01-2010, 12:14 PM
okay so a softer spring..right now it has a 350lb..what do you think i should jump down to? 250? and should i got to a taller spring or shorter spring?
firelizard
10-01-2010, 02:58 PM
What is your obession with spring heights?
If you go softer you could probably use a taller spring though, since it will compress more. Do some quick math to see how much more.
Red Sled
10-01-2010, 03:06 PM
no obession, just wanna make sure im getting the right thing. new at the whole coilover/coilover sleeve thing thats why i came here. i have always ran springs.
Spoon
12-04-2010, 06:00 PM
Hella late, but any update on this fool? Keep the damn springs already man. Firm shocks FTDW! ;)
